Make "offset edge loop" slide evenly
Confirmed, LowPublicTO DO
Graphics card: GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Just repeat the video example
Revisions and Commits
I can reproduce it, but I'm not sure if this is a bug.
@Vyacheslav (hitrpr) what would you expect exactly?
@Campbell Barton (campbellbarton) should this work differently?
@Jacques Lucke (JacquesLucke)
I expect even distance between edges. the same way as solidify do it, for example.
even edge offset literally: edge offset from edge, not vertex from vertex as it is now.
Not a bug but wrong behaviour, as I think.
Seems to be a creative cover for 'offset edge loops slide' aka 'offset edge slide' aka [shift-ctrl + r], an implementation that has always worked this way.
Campbell Barton (campbellbarton) renamed this task from Offset edge loop cut do not make even spaces to Make "offset edge loop" slide evenly.Sep 18 2019, 3:18 AM
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to Low.
Campbell Barton (campbellbarton) edited a custom field.
This isn't a bug, although this could be supported.
Note that making the offset "even" can cause spikes, so we'd want this to be an option - as it is for shrink/fatten "offset even" option.
Offset "even" doesn't help with the OP-selected geometry:
These are two different kinds of even.
  • The existing option moves a fixed distance from one side of the edge loop.
  • The other option (which this report is asking for) would increase the offset based on the angle between the edges.
Yeah, one of the most needed functionality considering edge slide, alongside with edge flow and curvature support.
