NVIDIA issue prevents full indirect draw call batching performance #70011
16 Participants
Reference: blender/blender#70011
Operating system: Linux-5.2.0-2-amd64-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: Quadro RTX 6000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.40
Broken: version: 2.81 (sub 11), branch: master, commit date: 2019-09-18 08:49, hash:
e2cbf8b117
Going to edit mode makes links in node editor to disappear.
Open attached file, go to object's edit mode.
Seems something to do with
/* Add link to batch. */
code path. Forcing/* Draw single link. */
code math makes all links to properly display.untitled.blend
Added subscriber: @Sergey
#70311 was marked as duplicate of this issue
#70275 was marked as duplicate of this issue
#70271 was marked as duplicate of this issue
#70212 was marked as duplicate of this issue
#70097 was marked as duplicate of this issue
#70008 was marked as duplicate of this issue
#70024 was marked as duplicate of this issue
Added subscribers: @WackyAman, @RobTuytel
Added subscriber: @brecht
This is only a display issue, but highly confusing. It should be fixed asap.
This was caused by
3a08153d7a
.I cannot reproduce on any of my setups (even linux + nv430.40). I'm trying to figure out what's happening.
Added subscribers: @alonabrany, @fclem, @JacquesLucke
Ok both Linux + GTX 960M (driver 430.40) and Win 10 x64 + GTX 960 with latest drivers are working correctly. So I'm guessing it's an issue with the RTX card driver.
The issue is caused by glMultiDrawElementsIndirect & glMultiDrawArraysIndirect which leads to apparent issue in rendering instancing drawcalls (glDrawElementsInstanced, glDrawArraysInstanced and the like)
Cleaning up the mapping does not fix it. (unmapping before changing context or other draw)
Removing the MultiDrawIndirect calls fixes it.
I'll report the issue to NVidia.
EDIT: Something I forgot to mention: No error is generated by the GL either by the debug facility (--debug-gpu) or by manually querying glGetError().
Jacques is using GTX card as far as i know though.
Added subscribers: @isvart86, @crantisz
Added subscribers: @smramsay, @lichtwerk
Added subscriber: @ChrisGraz
Added subscriber: @TomaszMuszynski
Added subscriber: @StephenSwaney
Happens here on Linux GTX 1660 with Nvidia driver
Added subscriber: @albo
Happens here on Win10 RTX2070 driver 431.53
Added subscriber: @mugpet
Added subscribers: @Insertzs, @Russ1642
@fclem, please commit whatever workaround is needed to fix this issue, even if it means disabling some of the batching optimizations for NVIDIA. We can't leave an issue with this priority broken for so long in master.
This comment was removed by @ChrisGraz
I'm using 10 bit colour with my RTX 2080 Ti and the bug is still there.
The committed workaround breaks meshes/objects. Trying to move the default cube in object mode just moves the origin and not the mesh.
Opening a file saved pre-commit moves all meshes (but not object origins) and empties to the world center.
Sorry if this isn't the place to report it and I'll open a new bug report if it's just on my end.
(Linux / 2070)
Added a more restricted workaround in
24be998
due to problems in #70345 (viewport display not showing the correct object transform (location & scale) with the lastest nightly build).Shader node link disappears when going to edit modeto Various display issues on NVIDIA after draw call batchingSo we went for an aggressive workaround since it could also affect bones. The workaround was to disable indirect drawing for all Nvidia hardware. This has some performance issue but some of the batching performance gain are still in.
About the bug itself, note that only the next instanced drawcall (that is after some buggy indirect drawcall), is not working.
The indirect drawcall that seems to be responsible for the buggy behavior seems to be any drawcall inside the edit mesh pass (bypassing edit_mesh_draw_components fixes it). But for the other problems (other missing instanced drawcall) the culprit indirect drawcall is another.
We tried to replicate the bug in a small test program but couldn't. The issue must come from a special state setup or a special sequence of events.
Added subscriber: @Psy-Fi
Is it possible to capture the render state with something like Renderdoc? Might give you a few hints.
If you haven't tried it already, it might be an issue with alignment of the data in the indirect buffer (wild guess though).
Removed subscriber: @ChrisGraz
This issue is caused by the latest workaround:
These issues were solved by it:
3a08153d7a
introduces X11 error)@Psy-Fi We already tried renderdoc but there was nothing standing out.
Indirect buffer is aligned correctly as all indirect calls are rendered correctly on every platform that support it. We also tried uploading the indirect buffer using glBufferData or glBufferSubData but that changed nothing. So it's not buffer management.
Added subscriber: @Phigon
Lowering priority since there is no known breakage here, just a potential performance improvement by getting indirect calls to work on NVIDIA.
Various display issues on NVIDIA after draw call batchingto NVIDIA issue prevents full indirect draw call batching performanceFor 2.81 we can just keep this disabled and live with somewhat reduced performance, but still better than 2.80.
Removed subscriber: @Phigon
Added subscriber: @dgsantana
So NVidia replied and said it was indeed a known driver bug (affecting Turing GPUs) that will be fixed in the next iteration of their drivers (version 440) to be released early next month.
So we should whitelist this driver version before release preferably.
On windows they already release 440 and 441. On Linux there is a 440 beta driver.
Probably this is not important enough to risk for the 2.81 release, seems simpler to just postpone it to 2.82.
Added subscriber: @ValZapod
@brecht @fclem Hey, that is not a good idea. At least maybe test it? What version of driver fixed that, you know. Also maybe try to check what connected issues were indeed because of those indirect calls. Maybe some of them used them wrong, then it is a problem, etc, etc. Also are you aware of a new Studio driver with optimized V-ray and Blender - [x]? Did you already check it?
Also it has some fixes - [x] in Optix, in particular:
[OptiX]: OptiX unable to select GPUs for use when all GPUs in the system are in TCC mode
[2722686]
[OptiX]: Applications built against OptiX SDK 7.0.0 throw error message when using
OptixBuildInputTriangleArray::preTransform. [2742029]
[OptiX denoiser]: Errors occur when using the denoiser and specifying Color + Albedo +
Normals.
[OptiX denoiser]: The Alpha-denoising path does not support blend mode. [2727732]
[OptiX denoiser]: OptiX errors occur when specifying Normals + Albedo for input. [2712572]
[OptiX]: noinline function calls do not use custom ABI. [2631716]
[OptiX]: denoiser device handling preempts user control. [2647842]
[OptiX denoiser]: OptiX denoiser produces small color values for black pixels and zero alpha.
[2545368]
Will be very happy if you polished Blender for Nvidia driver as Nvidia polished driver for you ;)
Ok revisiting this one. I think we can enable it to all Nvidia GPUs now and display a warning about unsupported driver.
@brecht any issue with that?
It depends if that driver update is available for all NVIDIA graphics cards we support. I'm guessing it's not.
Safest would be to check the driver version instead, does that require complicated code?
Added subscriber: @EAW
@fclem Do you mean enabling the original version of
3a08153d7a
without the work arounds?@brecht If that is what @fclem is suggesting, then wouldn't the driver only have to be available for Turing aka RTX cards (which it is), since the original batch calling patch only produced errors on cards with this architecture? It is the workarounds that affected other architectures. With the work arounds removed, there shouldn't be an issue with cards with older drivers, right?
You're right, if it's only RTX cards this should be fine.
So final decision is to just remove the workaround right? @brecht
Yes.
But do it in master (which I guess you already planned to do), since this is rather risky close to the 2.82 release.
This issue was referenced by
fd130a711e
