TexturePainting: does not paint on faces where a vertice is behind the viewport #70128
6 Participants
Reference: blender/blender#70128
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.86
Broken: version: 2.81 (sub 12), branch: master, commit date: 2019-09-20 15:42, hash:
adfe68e202
I know that alpha, but still ... In Texture Paint layout, if you draw on the surface at a fairly right angle, then everything is fine, but if you tilt the camera, the brush stops painting.
Any model, including simple plain. When drawing in single texture mode and in material mode. When sculpting this is not observed.
Added subscriber: @Elevenlevel
Added subscriber: @Mets
I cannot reproduce this. Please provide clearer reproduction steps, perhaps screenshots, video, or a blend file.
https://1drv.ms/u/s!AgIaQataEAPAvhG0jP-TFDn75T9V Here's a short video example of how this works. Just a scene with a simple plane.
https://yadi.sk/d/Dot7CvhGMMil0w This is a scene from the video. I'm not sure that it is needed, since there is nothing special about it.
Thanks for the files. Please attach files directly to the tracker via drag drop, like so:
untitled.blend
I can reproduce the issue in that file, but not in a fresh file, so I feel like some option is causing it. Do you have any ideas?
Added subscriber: @capnm
This is a long-term bug that you can also abuse as a feature:
Should be easy reproducible:
blender --factory-startup → a, x → add plane → texture paint → single image → new → play with the viewport angle / zoom and paint
Ah yeah, I can do it in a fresh file now too. I guess I was just unlucky last time, and I didn't realize zoom level could influence it too.
Added subscriber: @Alumx
Adding more geometry to your object, greatly helps with this issue
2019-09-25 16-21-52.mp4
Added subscribers: @Jeroen-Bakker, @mano-wii
@Jeroen-Bakker, do you mantain this area?
It seems that when one of the vertices in the looptri is behind the camera the whole triangle is ignored.
It is a limitation of the current system; B279 shows same behavior.
With a strong tilt of the camera does not drawto TexturePainting: does not paint on faces where a vertice is behind the viewportAdded subscriber: @PabloDobarro
Just rechecked. This is a limitation of the current system, without an easy fix. Vertices are converted to screen space. When a vertice cannot have a screen space coordinate (for example in when a vertices is behind the viewport, the whole face is not selected for the stroke as it would always lead to undesired behavior (flipping strokes).
There are multiple possible solutions:
As texture painting system will be redone in the near future I don't think it is good to invest our time in fixing this issue in the old system.
@PabloDobarro do you agree with that?
Actually this is a known limitation of the system and also documented in the manual. Not considered a bug.
https://docs.blender.org/manual/en/dev/sculpt_paint/texture_paint/introduction.html#perspective-view-faces-behind-the-view
