16 bit transparent Image renders color data on CPU Cycles #70138
Reference: blender/blender#70138
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.02
CPU: Intel i7-4770k
Broken: version: 2.81 (sub 12), branch: master, commit date: 2019-09-20 22:35, hash:
7926e8ea4c
Rendering a transparent Filmic Log 16bit PNG image plane (meaning node color space set to filmic log) with Cycles the CPU renders color data where there should not be any. The GPU works as expected.
every thing with Cycles (have not tested eevee)
Switch Display Channels to color to see this issue
test.blend
Redner:
Used image:
Added subscriber: @Namnak
Added subscriber: @SteffenD
Added subscriber: @iss
Can not reproduce on ATI GPU
@Namnak Is this still an issue with latest build? https://builder.blender.org/download/
Tested it again under blender-2.83-1bcb2bfd5724-windows64 and it still happens.
@iss It has nothing to do with the GPU; the white squares are the CPU render tiles. GPU tiles are (as can be seen) correct, i.e. no/ black color (RGB) data and full alpha.
But seen that it is a super edge case and because it behaves as expected in normal renders (e.g. when the image plane is in front of other geometry), not sure if it is worth fixing (now).
Further tested the saved RGBA PNG file (see below) by opening it in a new blender instance and in Affinity Photo. Interestingly the blender compositer still shows the squares in the color channels. Affinity does not.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
@Namnak Thank you for additional information. Sorry I am not sure if I didn't accidentaly copied this "auto-reply" from another thread (lots of fairly old reports to go through).
I tested this, and couldn't see the difference between CPU and GPU render. But now I am looking at this closer, I see that in your render both black and white tiles are fuly opaque, while my render is transparent.
Can you tell us what compute you used (CUDA / OpenCL)? this is not stored in .blend file.
As to whether this is bug or not, I will leave to developers that are involved in rendering.
I'm rendering with CUDA (GTX 1080ti).
Sorry, maybe I was not clear in describing the "problem".
As you said, the final render looks completely correct, but looking at the R, G or B channel of the final render individually (by selecting them from the small menu in the top right corner) it can be noticed, that the transparent parts of the image plane are rendered white on CPU (and apparently ATI GPUs), while CUDA GPUs render black.
I have added my render to the file and selected the B color channel. Maybe this helps.
test_v2.blend
As mentioned before, this is only a problem when the final render has to be separated into the RGB(A) companies or when it gets saved as a JPEG image (because no support for alpha).
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
Thanks for additional info.
I can confirm this even on openCL.
Added subscriber: @brecht
There's a tiny precision difference between CPU and GPU, rendering pixels with 0.0 and 0.0005 alpha. This shows up significantly when inspecting the Color alone, but this is more of an artifact of Blender dividing out the alpha than an actual significant difference if you'd use save or use this render for compositing.
