Cycles: Tex Coord node plugged directly in a world shader does not affect diffuse rays
Confirmed, LowPublicKNOWN ISSUE
I tested and it's not supported in 2.79 so this maybe a corner case that has long been standing.
This happens also in final render.
  • Open given file and switch to rendered view.
  • Connect the 2nd checker color socket to another of the dysfunctional texco socket.
  • Only glossy rays can now see the texco of the environment.
The issue seems to happen if the coordinate is plugged straight to the background or emission node. If the output is mixed it does work (default state of the file).
Mixed, working:
Not mixed, broken:
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to Low.Sep 24 2019, 6:56 PM
Thanks.
Brecht Van Lommel (brecht) changed the subtype of this task from "Report" to "Known Issue".Wed, Feb 12, 10:34 AM
Brecht Van Lommel (brecht) edited projects, added BF Blender; removed Tracker Curfew.
