Viewport: Retopology Overlay #70267
Closed
opened 2019-09-26 11:17:05 +02:00 by Jeroen Bakker · 36 comments
Member
Created this subtask for testing several drawing techniques in order to create the Retopology overlay. Based on several implementation we can chose the best technique.
Biggest issues are that the wires should be visible on top of other meshes, but still be occluded by them.
The most common technique is to shift the depth buffer, but that will still introduce rendering atifacts.
The options we know so far we want to prototype are
  • Backface depth test buffer
  • Frontface depth test buffer
  • Average of Back and front face buffer
note: Above options still artifacts when looking on edges of meshes, but those are actually edge cases that might not be that disturbing but we need to test.
Please keep comments related to this topic.
This is with backfacing depth test. Results are ok when retopology mesh is finished
but when having a non-manifold mesh it will still render artifacts.
Using a stencil buffer to remove render artifacts introduces sharp edges
As non-manifolds is part of the process we should find ways how to remove these render artifacts.
Created this subtask for testing several drawing techniques in order to create the Retopology overlay. Based on several implementation we can chose the best technique. Biggest issues are that the wires should be visible on top of other meshes, but still be occluded by them. The most common technique is to shift the depth buffer, but that will still introduce rendering atifacts. The options we know so far we want to prototype are * Backface depth test buffer * Frontface depth test buffer * Average of Back and front face buffer note: Above options still artifacts when looking on edges of meshes, but those are actually edge cases that might not be that disturbing but we need to test. Please keep comments related to this topic. This is with backfacing depth test. Results are ok when retopology mesh is finished ![image.png](https://archive.blender.org/developer/F7776656/image.png) but when having a non-manifold mesh it will still render artifacts. ![image.png](https://archive.blender.org/developer/F7776670/image.png) Using a stencil buffer to remove render artifacts introduces sharp edges ![image.png](https://archive.blender.org/developer/F7776962/image.png) As non-manifolds is part of the process we should find ways how to remove these render artifacts.
Jeroen Bakker self-assigned this 2019-09-26 11:17:05 +02:00
Author
Member
Added subscriber: @Jeroen-Bakker
Added subscriber: @ErickNyanduKabongo
Member
Added subscriber: @PabloDobarro
Added subscriber: @kioku
Added subscriber: @TheRedWaxPolice
Added subscriber: @1D_Inc
We're hiding parts of meshes, so we're able to get rid of depth tests on hardware, providing the power to display complex models during retopology.
100% quad manifold surface, made by manual retopology:
We're hiding parts of meshes, so we're able to get rid of depth tests on hardware, providing the power to display complex models during retopology. 100% quad manifold surface, made by manual retopology: ![BUST.jpg](https://archive.blender.org/developer/F7779938/BUST.jpg)
Added subscriber: @ReguzaEi
Author
Member
@1D_Inc Sorry, I don't get what you want to tell.
Keep it up, you are making great job, keeping patch at low performance loss level.
> In #70267#786822, @Jeroen-Bakker wrote: > @1D_Inc Sorry, I don't get what you want to tell. Keep it up, you are making great job, keeping patch at low performance loss level.
Added subscriber: @karatastamer
Added subscriber: @TheCharacterhero-4
Added subscriber: @item412
Added subscriber: @Gwobbler
Contributor
Added subscriber: @jmztn
Added subscriber: @A.Lex_3D
Added subscriber: @lemenicier_julien
Jeroen Bakker changed title from Prototype Retopology Overlay Drawing Techniques to Retopology Overlay Drawing Techniques 2019-11-27 08:11:47 +01:00
Jeroen Bakker changed title from Retopology Overlay Drawing Techniques to Viewport: Retopology Overlay 2020-01-22 09:25:26 +01:00
Added subscriber: @Jayanam
Added subscriber: @thromshall
Added subscriber: @JonathanLampel-4
Added subscriber: @xan2622
Added subscriber: @danilor
I struggled with this for a long time, and finally found a workaround... not sure if this is of any help, but I can hide now undesired back faces in edit mode when doing the retopo. I just create instanced copy, set to in front, and turn back faces culling on. That way the hi-poly mesh is hiding my editing mesh, and in front instance is showing the vertices that are in front
Contributor
Added subscriber: @KenzieMac130
Added subscriber: @rwman
Added subscriber: @derksen
Hey, did you completely forget about this feature?
Added subscriber: @Norman.Higuera
Added subscriber: @AlRedd-3
Hi there! Any news on this? What needs to be done for it to be committed?
https://gumroad.com/l/draw_xray This addon is working well. Only thing is that you can still select points on the other side
> In #70267#1069045, @AlRedd-3 wrote: > Hi there! Any news on this? What needs to be done for it to be committed? https://gumroad.com/l/draw_xray This addon is working well. Only thing is that you can still select points on the other side
Added subscriber: @sid350
Jeroen Bakker removed their assignment 2021-04-12 15:39:14 +02:00
Added subscriber: @sleepyhead
Added subscriber: @Dangry
Contributor
Added subscriber: @Nika-Kutsniashvili
Julien Kaspar added this to the Sculpt, Paint & Texture project 2023-02-08 10:48:53 +01:00
Julien Kaspar removed the
label 2023-02-08 10:58:24 +01:00
Julien Kaspar removed this from the Sculpt, Paint & Texture project 2023-02-08 10:59:02 +01:00
Philipp Oeser added the
label 2023-02-08 12:27:01 +01:00
Philipp Oeser removed the
label 2023-02-09 15:15:18 +01:00
Member
I think this can be closed now. The overlay is already implemented.
Blender Bot added
and removed
labels 2023-05-21 11:38:05 +02:00
29 Participants
Reference: blender/blender#70267
