Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.81 (sub 12), branch: master, commit date: 2019-09-25 20:42, hash: rBee4707544904
2.80
In Node Editor there is a problem with connection lines: they are not shown or disappear when reconnecting other nodes
This problem appears when Blender uses non-default user startup file, as I have investigated so far.
Cause even after Load defaults then Save config and reopen Blender ( it starts with my startup file ) does not solve this problem.
I think that is something not right if user have to rebuild his workplace from scratch every time when software is updated.
Please investigate this case. Thank you.
