VSE Speed Control Error BUG #70297
2 Participants
Reference: blender/blender#70297
Blender Version: Tested with blender 2.8, but all versions. Ancient bug.
When you cut a video strip with a speed controll video strip, the newly generated strip doesn't start from the frame where it should.
When loading the .blend you only have to execute one cut, with K or Shift+K and you can see in the preview panel, above, that the execution jumps and should not.
You must select both strips, the video and the speed control.
I have also noticed that if before creating the cut, you convert the two strips into a meta strip, this error does not occur.VSE Speed Control BUG.blend
Attached .blend
Added subscriber: @Blade-3
I'm sorry I forgot the video file.Prueba.mkv
Added subscriber: @iss
This is covered by #59540
Speed fx basically changes framerate of strip, and Blender currently doesn't support this very well.
To avoid many task open caused by same design issue, this task will be closed.
If you want to be notified on progress of this issue, you can subscribe to task mentioned.
