Memory Increased #70338
Closed
opened 2019-09-29 00:27:33 +02:00 by Ishaq Al Asyja' · 17 comments
Operating system: Windows 10
Graphics card: AMD A10-7300 Radeon R6
Broken: 2.81 1c1a3198af
When I working, the memory in the Task Manager has increased. Don't know why.
**System Information** Operating system: Windows 10 Graphics card: AMD A10-7300 Radeon R6 **Blender Version** Broken: 2.81 1c1a3198af9d When I working, the memory in the Task Manager has increased. Don't know why. ![Untitled1.png](https://archive.blender.org/developer/F7779015/Untitled1.png) ![Untitled2.png](https://archive.blender.org/developer/F7779014/Untitled2.png)
Added subscriber: @Ishaqalasyja
Added subscriber: @brecht
There can be many causes. The undo system is a likely one, you can change in Preferences > System how much memory it can use. If that's it, it's not likely to be a bug, but expected behavior.
In any case, to investigate reports we need a .blend file and exact steps to reproduce the problem.
There can be many causes. The undo system is a likely one, you can change in Preferences > System how much memory it can use. If that's it, it's not likely to be a bug, but expected behavior. In any case, to investigate reports we need a .blend file and exact steps to reproduce the problem.
[Ren (Cyber).blend](https://archive.blender.org/developer/F7779030/Ren__Cyber_.blend) [Ren (Cyber).blend1](https://archive.blender.org/developer/F7779036/Ren__Cyber_.blend1)
I already have it, but it still increasing in task manager.
Added subscriber: @iss
@Ishaqalasyja does it help if you save file and reload?
Does memory usage info, you can see in bottom right corner correspond to usage in task manager?
how many undo steps you do have enabled and what is your undo memory limit?
It would also help to know what operations are you performing that would increase memory usage the most.
@Ishaqalasyja does it help if you save file and reload? Does memory usage info, you can see in bottom right corner correspond to usage in task manager? how many undo steps you do have enabled and what is your undo memory limit? It would also help to know what operations are you performing that would increase memory usage the most.
Ishaq Al Asyja' self-assigned this 2020-01-13 22:51:28 +01:00
Yes, it do help if I save file and reload (but must exit the app). Due increase of the memory in task manager, I saw that the memory usage on Blender is not equal as memory on task manager. Memory limit is 1,5 Gb and undo steps is 10.
Ishaq Al Asyja' was unassigned by Richard Antalik 2020-01-14 09:53:58 +01:00
@Ishaqalasyja Please change memory limit to 500MB initially and report if this helps.
Ishaq Al Asyja' self-assigned this 2020-01-14 11:26:34 +01:00
Not work
Not work
![20200114_172853.jpg](https://archive.blender.org/developer/F8277729/20200114_172853.jpg)
Ishaq Al Asyja' was unassigned by Richard Antalik 2020-01-20 00:25:42 +01:00
@Ishaqalasyja Please don't claim this task - that it is for person, that should resolve the issue.
Unfortunately we are not able to help you unless you can point to what causes high memory usage. Ideally if you can at least try to repeat some steps multiple times or watching at memory usage as you work and tell us that feature X uses too much memory we may be able to help you.
@Ishaqalasyja Please don't claim this task - that it is for person, that should resolve the issue. Unfortunately we are not able to help you unless you can point to what causes high memory usage. Ideally if you can at least try to repeat some steps multiple times or watching at memory usage as you work and tell us that feature X uses too much memory we may be able to help you.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Member
Added subscriber: @Blendify
Member
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
Aaron Carlisle self-assigned this 2020-02-18 19:27:18 +01:00
Member
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
5 Participants
Reference: blender/blender#70338
