I can't use the hotkeys Ctrl + T
Closed, InvalidPublic
Operating system: win 10
Graphics card: 1060
Broken: 2.80
(example: 2.79b release)
I can't using the "node"'s hotkeys (for like pressing the ctrl + t doesn't works )
Philipp Oeser (lichtwerk) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Mon, Sep 30, 4:47 PM
I assume this is about the Node Wrangler Addon?
  • Do you have this enabled?
  • Please try with File → Defaults → Load Factory Settings, then enable the Addon and report back if this still fails...
