Alembic import - Incorrect object pivots #70408
Reference: blender/blender#70408
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon R9 M370X OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.11.20
Broken: version: 2.81 (sub 12), branch: master, commit date: 2019-09-22 20:38, hash:
52bdf522af
Alembic import places pivots of objects at origin, ignoring object pivot data in the file.
Import pivot_debug.abc in Blender
Observe pivots of all objects at 0, 0, 0
When pivot_debug.abc is imported back into Maya, the pivots are in their expected locations.
pivot_debug.abc
Added subscriber: @Frand
Added subscribers: @dr.sybren, @lichtwerk
Not sure about this.
Blender seems to be able to preserve pivot points just fine.
If I import
pivot_debug.abc
into an empty scene, select all meshes, doObject
>Set Origin
>Origin To Geometry
and export as alembic again, I end up with#70408.abc
We can also remove the parent empty for clarity:
T70408_no_parentempty.abc
If I import that, pivots are preserved just fine.
Now what is the difference between
pivot_debug.abc
and#70408.abc
?We can look at it with
abcls
@dr.sybren: I assume this is about the different XFormOps ? Is there a resource where we can find out about these used values [we: 48, them: 19, 19, 17, 17]
(couldnt find anything on https://docs.alembic.io/search.html?q=Xform)
The objects are exported from Maya 2019.1, please let me know if there are specific test objects you'd like me to generate.
Attached is the case of a cube with the pivot manually set to the center of its top face. The file imports back to Maya with the pivot in the same location.
testCube.abc
This is
abcls
for that file (still assume it has to do with the.ops
part of the XForm?)Only thing I can think of is we are not hadling (more or less a stab in the dark...)
Alembic::AbcGeom::kScalePivotPointHint
Alembic::AbcGeom::kRotatePivotPointHint
https://github.com/alembic/alembic/blob/master/maya/AbcImport/XformHelper.cpp
@dr.sybren: does this ring a bell?
Blender simply uses the transformation matrix of each object, which is constructed from the Alembic file by the Alembic library itself (source). The Alembic file can contain various separate operations, or the final matrix. In the case of this Maya-generated file, it contains a sequence of operations. This is such a sequence:
As you can see, the transformations cancel each other out, and result in a unity matrix. The same you can see in the cube example.
Maya has a pivot point that is separate from the object origin, and it encodes this pivot point in the transform operations. Blender doesn't have a separate per-object pivot point, so we cannot load this information. To use the pivot point as object origin, bake the pivot points in Maya and then export to Alembic.
Closing this as 'Invalid' as this does not constitute a bug in Blender.
In Maya, I do notice the pivot point referred to as RotationPivot, so this may very well be it.
thx for learing that up @dr.sybren
Thank you for the explanation, baking pivots in Maya resolves our problem.
