Middle mouse turns from rotate to zoom #70482
Closed
opened 2019-10-03 16:44:48 +02:00 by David · 13 comments
Imac 2019 Intel Core i9 8 cores
40GB Ram
Operating system: Mac Os Mojave 10.14.6
Graphics card: Radeon Pro Vega 48 8GB
Broken: Version 2.8
Middle Mouse button stops rotating and turns into zoom and scrolling does not work. And any other command stops working for exammple "Shift + A" , multiple select, etc. Only rotates
When start up middle mouse button is good until I press Shift Option and everything stops working. Here is a link to a video explain the situation https://youtu.be/pnJlvUOtXd0
Thanks for your hard work
Imac 2019 Intel Core i9 8 cores 40GB Ram Operating system: Mac Os Mojave 10.14.6 Graphics card: Radeon Pro Vega 48 8GB **Blender Version** Broken: Version 2.8 **Short description of error** Middle Mouse button stops rotating and turns into zoom and scrolling does not work. And any other command stops working for exammple "Shift + A" , multiple select, etc. Only rotates **Exact steps for others to reproduce the error** When start up middle mouse button is good until I press Shift Option and everything stops working. Here is a link to a video explain the situation https://youtu.be/pnJlvUOtXd0 Thanks for your hard work
Author
Added subscriber: @DavidSanchezTorres
Member
Added subscriber: @lichtwerk
Member
I cannot reproduce this with either the latest stable or current development versions of Blender:
  • Please download the latest build from http://builder.blender.org.
  • Go to File → Defaults → Load Factory Settings and then load your file to see if you still can reproduce this issue.
  • Also: is there anything in your OS capturing the Shift key for some reason? [do other programs still permit Shift+modifier commands?]
I cannot reproduce this with either the latest stable or current development versions of Blender: * Please download the latest build from http://builder.blender.org. * Go to File → Defaults → Load Factory Settings and then load your file to see if you still can reproduce this issue. * Also: is there anything in your OS capturing the Shift key for some reason? [do other programs still permit Shift+modifier commands?]
Added subscriber: @mont29
Bastien Montagne self-assigned this 2019-10-14 11:23:50 +02:00
Added subscriber: @Jonathan_Heuschen
Yes, this happened to me too. Strangely enough, clicking on another software tab and coming back in Blender "fix" the issue but not really. As soon as I press shift, it doesn't work anymore. Once shift and MMB has been pressed, all it does is zooming. It was working until some point. Also using a Mac Pro.
So if i get out of blender to display another app then go back in Blender, the MMB button pressed alone do rotate, but as soon as I press shift, alt, ctrl, or cmd: it zoom when pressed. Then all it does is zoomed even if MMB is pressed alone. The scroll doesn't respond anymore either.
Loading factory setting didn't resolve the problem.
I wonder, but I am not sure, if the issue started after I used the Wacom for some sculpting.
Yes, this happened to me too. Strangely enough, clicking on another software tab and coming back in Blender "fix" the issue but not really. As soon as I press shift, it doesn't work anymore. Once shift and MMB has been pressed, all it does is zooming. It was working until some point. Also using a Mac Pro. So if i get out of blender to display another app then go back in Blender, the MMB button pressed alone do rotate, but as soon as I press shift, alt, ctrl, or cmd: it zoom when pressed. Then all it does is zoomed even if MMB is pressed alone. The scroll doesn't respond anymore either. Loading factory setting didn't resolve the problem. I wonder, but I am not sure, if the issue started after I used the Wacom for some sculpting.
Added subscriber: @Egorsurfer08
did you guys fix it?
because I have it too and I can't fix it in any way
please help
did you guys fix it? because I have it too and I can't fix it in any way please help
HEY GUYS I JUST FIXED the problem it was the (Wacom applications)
if you get rid of them it fixes the problem
HEY GUYS I JUST FIXED the problem it was the (Wacom applications) if you get rid of them it fixes the problem
Author
Awesome! @Egorsurfer08 I fixed but didnt know which of all applications was messing with me I just reinstalled the wacom aplication and others and done fixed. But at least its good to know it was the wacom app all along. Thanks
Yes, reinstalled the Wacom latest driver and the bug disappeared. I hope it won't occur again if i want to use the tablet. Sculpting is more fun and intuitive with the stylus.
5 Participants
Reference: blender/blender#70482
