Blender crashes when going into "rendered" viewport mode using cycles. #70490
7 Participants
Reference: blender/blender#70490
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 425.31
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash:
f6cb5f5449
So essentially Blender 2.80 AND 2.81 crashes when I switched to rendered viewport mode using Cycles, after modifying the material on my object. Material(tab)->Settings->Surface->Displacement(Displacement and Bump)
I'm going through a tutorial (Blender Guru's Beginner tutorial for 2.8 video level 2 part 4: Procedural displacement) so it has several steps. I don't remember it all, however, i'm going to go ahead and attach the actual blend file and to be able to reproduce the problem from the blend file, make sure the renderer is set to cycles, with sample size of 32 for both render and viewport. Then simply make sure Dispacement and Bump is set on the material tab as outlined above. And select "Rendered" viewport shading. It should start to render in cycles and go for a bit and then after less than a minute it should crash.
Donut_00001.blend
Here is the texture should be in the same folder/directory as the blend file
AS A QUICK UPDATE: It appears that if in the shading tab you change the scale in the displacement node from 1 to something really small like 0.001 it doesn't crash then. So presumably scale of 1 caused some super massive geometry that kills the GPU. In fact it won't crash in CPU mode.
Added subscriber: @Uhfgood
Added subscriber: @mano-wii
I can't reproduce the crash in my GPU (OpenCL)
Operating system: Windows-10-10.0.18941 64 Bits
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.13559 Core Profile Context 26.20.12028.2
Added subscriber: @iss
@Uhfgood Is this still an issue with latest build? https://builder.blender.org/download/
Closing because there has not been a response for a week. If you are still able to reproduce the issue in the latest builds and with latest gpu drivers, reopen the report please.
Added subscriber: @brokenstyli
I'd like to chime in and say that I'm having a similar issue, but the crash appears to only occur when using Eevee and wireframe/solid mode viewport renderers, not Cycles (in fact, I'm able to render out an image completely as expected in Cycles).
I'm following along the same tutorial series. My machine's information are as follows;
Steps to Reproduce
Create the above pictured material node graph, apply material to a torus mesh. Enable Displacement + Bump in the settings of the material panel, as mentioned in the OP. Switch from Shading workspace tab to Modeling/Sculpting/Layout workspace tabs. Crash happens a few seconds after switching workspaces.
Other important details;
I'm not able to check the latest builds, and do not know how to reopen a report.
I would recommend to file new repor if this is not reported and please follow guidelines (include.blend file)
Added subscriber: @NoHow
Hi,
i have a gut feeling that this is again a problem with the Windows TDR feature, espacialy if it happens after a >2sec GUI freeze!
SubstancePainter had this issue and they wrote a nice documentation/fix for that:
https://docs.substance3d.com/spdoc/gpu-drivers-crash-with-long-computations-128745489.html
I've found this so often across various projects on the internet, wasting the precious developers time.
So, if it solves this problem.... please spread the word!
Added subscriber: @SteffenD
This is a main cause for errors, especially with less experienced users. The problem is that any Windows or nVidia drivers update can reset these values in the Registry :(
Allegorithmic had enough "bug" reports because of this issue and so they not only released a documentation on how to fix it but also added a check during the startup of Substance Painter that warns you in case your TdrDelay and TdrDdiDelay values were too low.
Maybe such a check should be added to the Windows version of Blender.
