EEVEE: color mix node set to "darken" wont work anymore with fac < 1 #70605
Reference: blender/blender#70605
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 388.31
Broken: version: 2.81 (sub 10), branch: master, commit date: 2019-09-09 20:20, hash:
3e81c1c1d5
color mix node in eevee set to darken wont result in correct output, when fac is lower than 1
add a colormix to the surface shader's color (for example). set the mix mode to darken. choose white as color1 and a dark color as color2. gradually change the factor value. you see a different behaviour in cycles, where the white output at factor 0 darkens when raising the factor to 1.
in eevee at factor 1 its correct, but it only turns black, as you lower the factor to 0. It should turn white, like in cycles.
Added subscriber: @office
I can confirm the issue. The behavior is different between Cycles and Eevee when changing the factor.
darken_color_bug.blend
Eevee:
Cycles:
I believe the cycles version makes more sense. Will create a patch.
Added subscriber: @brecht
On the other hand, when comparing this to the
light
function, the more eevee-style solution is used by cycles as well.Eevee:
Cycles:
@brecht, which one of the darken functions is the correct one? I think it makes sense that if the factor is zero, the output is exactly the first color. I think the factor should just be a mix factor between the first color, and the mixed color. With this definition
mix_dark
,mix_light
andsvm_mix_light
are wrong.thanks for giving this a closer look! photoshop would have the layers opacity as "factor". hence factor would just mix between col1 and the result of the col1&col2 blend, like brecht said. that is what i as a user would expect (due to photoshops layeropacity)... but i dont wanna bother you. thank you!
@JacquesLucke I think the Cycles version should be used for dark. You can change light in both to work similar.
This issue was referenced by blender/cycles@04b93ebff0
2a9b162d94
