Quadriflow remesh fails on provided model #70608
Reference: blender/blender#70608
I'm getting following error when running the quadriflow command on the mesh in attachment:
bpy.ops.object.quadriflow_remesh(target_ratio=0.5, target_faces=41900)
QuadriFlow: remeshing failed!
Perhaps this is the limitation of this tool? quariflow mesh error.blend
Added subscriber: @Schiette
Added subscriber: @SomeAB
I can confirm that Quadriflow fails on certain models sometimes .. while it can work with the very same model after a few tries. I was trying to remesh a leaf yesterday. I don't know why exactly this was happening .. so didn't report it yet.
Added subscriber: @ZedDB
The issue with this file is that none of the triangles in the mesh is connected to each other. So it does not form a continuous surface and thus quadriflow can't create a mesh for it.
However, even if we merge the verts to make it a continuous surface, the results are not good:
This is the same issue as reported here:
https://github.com/hjwdzh/QuadriFlow/issues/43
This is a fundamental problem with how the quadriflow algorithm works so there is not much to do as we do not have time to come up with a better algorithm for quadriflow.
For this case instead of using quadriflow, I would
merge by distance
and then use thetris to quads
operator.Then use the decimate modifier (with the un-subdivide option) to get the polygon count down.
Thank a ton @ZedDB . I'm still starting out with Blender and didn't think of checking whether the mesh was continuous.
The steps you described worked perfectly.
