Perpendicular planes are not selected with Box Select tool
Closed, DuplicatePublic
Operating system: Windows-10-10.0.15063 64 Bits
Graphics card: Quadro K2200/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.78
Broken: version: 2.81 (sub 14), branch: master, commit date: 2019-10-09 22:31, hash: rBf61a8a2abd07
Worked: (blender 2.77)
I just can't select any object, that are perpendicular to view:
Have to switch to perspective or do some rotate view. When you add to this issue with selecting too small objects (https://developer.blender.org/T63356), that causes your work hard.
  1. Remove everything from scene.
  2. Switch to top view.
  3. Add a plane.
  4. Rotate it 90 degree X axis.
  5. Duplicate it many times.
  6. Select them using border select tool.
  7. Notice, that only active element was selected.
I intentionally placed GIF with all nonactive objects. Circle select and Lasso select tool work fine.
This is really tied to T63356 very much.
It is really the same issue to be honest (though a special case - perpendicular planes would make it even harder to show up in any drawing method).
But I dont think it is worth having a separate report open for this.
Btw.: workaround for now (that was also mentioned in T63356) is to enable Viewport Overlays > Origins (All) -- this makes sure you have something selectable shown in the viewport.
Philipp Oeser (lichtwerk) renamed this task from Selecting from perpendicular view with border select tool problem to Perpendicular planes are not selected with Box Select tool.Thu, Oct 10, 12:17 PM
