Problem with bpy.ops.object.material_slot_assign () when running a script from the console
Operating system: Linux-5.2.18-129.current-x86_64-with-glibc2.9 64 Bits
Graphics card: GeForce GTX 660/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.50
For automation I created a script from a sequence of actions which works great if I run it in the blender console window, or if i Run Script in a text editor.
But when I run this script through the command line without the graphical shell of the blender - he crashed.
If I exclude bpy.ops.object.material_slot_assign (), the script succeeds, except that the materials are not used.
Problem is repeated regardless of the platform, Windows or Linux, regardless of the PC used (3 different PCs).
./blender -b -P /home/convert/script.txt
The error is reproduced even in the simplest example
import bpy
bpy.ops.object.editmode_toggle()
bpy.ops.mesh.select_all(action='SELECT')
bpy.context.object.active_material_index = 0
bpy.ops.object.material_slot_assign()
In a full script, everything is executed until it reaches the line bpy.ops.object.material_slot_assign ()
Without this line, the script completes successfully and the result is saved.
And it does not depend on the assigned material.
I also attach an automatically generated file when the blender falls:
Bastien Montagne (mont29) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.
That operator is not designed to work without UI at all, it expects a valid 3DView from the context.
Will tweak the poll function of those ops to properly abort when this is not available, instead of crashing…
Hrmmm, actually it’s a bit more involved, not sure why we need view3d here, still digging.
Bastien Montagne (mont29) closed this task as Resolved.Fri, Oct 11, 8:44 PM
Grmlll, broken auto-close with fixes in release branch it'd seem… Fixed by rB1c2a20c84d46d30b.
Thank you guys, you are the best and thank you for making the best program.
