functools.partial wrapped functions can't be used for bpy.props.XXXProperty update callbacks #70742
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#70742
Operating system: Win 10
Graphics card: 1070 8gb
Broken: current 2.81 master
I'm working on a in Python node graph and I need updates on every property change; this is proving more difficult than I would have guessed. I tried to implement a default update function that will optionally wrap the function specified at attribute declaration like so:
Attribute in class is declared like this:
On registration, it errors:
I'd think functools.partial objects should work, so I consider this a bug.
Thanks!
Added subscriber: @CharlesWardlaw
Added subscriber: @Blazej-Floch
Note:
In source/blender/python/intern/bpy_props.c:1657
PyFunction_Check could be PyCallable_Check. Not sure if the PyFunction_GET_CODE would still work, but I believe there are functions to do the same with callable objects.
It uses PyObject_CallObject to call so I guess that should work.
Added subscriber: @PixelTrader
Added subscribers: @ideasman42, @mont29
There is no bug here, things are working as expected, with some limitations indeed. This is a complex mix of python and blender API, you cannot always use all the magic of pristine python with it.
Not saying that improvements here are not possible, but this tracker is for actual bugs, not feature requests. Although if someone wants to work on a patch, it would always be welcomed, of course.
Maybe check with @ideasman42 first though, not sure what would be the implications of such change as the one suggested by @Blazej-Floch (there are other considerations to take into account, like performances e.g.).
Agree this isn't an error in the code, however it's not a problem to support this.
