VSE: Grabbing and dropping strips with a crossfade on them can cause incorrect snapping #70844
6 Participants
Reference: blender/blender#70844
Broken: 2.80
In the VSE: when grabbing/dropping a strip that has a crossfade attached to its left side, on top of another strip, the crossfade can block the strip from snapping where it should, causing the dropped strip to snap backwards in front of other strips.
Difficult to describe, but easy to see in action:
The dropped strip SHOULD snap to the leftmost edge of the right strip, but it will now snap back to the left of the leftmost strip
Expected behavior
The dropped strip should snap to the leftmost edge of the right strip, exactly how it would behave if the crossfade were not there.
Added subscriber: @snuq
Please prepare a simple .blend file (using simple color strips) to make reproducing the issue much easier.
ok, here's an example file -
blender grab bug.blend
Press G to move the selected strip (titled 'Grab This'), drop it so its a little bit over the right strip (when it turns red).
Delete the transition (strip between the left strip and grab this) to see how its supposed to behave.
Added subscribers: @iss, @mano-wii
I can confirm.
It is easy for the user to work around this problem, so I put low priority.
@iss, is this your area?
Will look into this, still working on high prio stuff
Added subscriber: @SHREY-AGGARWAL
I have proposed a fix for this issue : D14578
This issue was referenced by
502f3debf9
