Pivot Center doesn't compute mirror elements #70873
Closed
opened 2019-10-16 14:44:56 +02:00 by Wayne Dixon · 7 comments
Operating system: Darwin-17.2.0-x86_64-i386-64bit 64 Bits
Graphics card: NVIDIA GeForce GTX 1050 Ti OpenGL Engine NVIDIA Corporation 4.1 NVIDIA-10.27.6 378.10.10.10.20.109
Broken: version: 2.82 (sub 0), branch: master, commit date: 2019-10-16 09:29, hash: a3f7ae1b96
When you scale around the median point with x axis mirroring enabled, the result is not calculated from the median.
see video.
Add circle mesh
turn on x axis mirroring (or any other axis)
It will give an unexpected result (unless you have topology mirror also enabled)
This does not work the same as 2.79 (excluding the extra axes of course)
x_axis_mirror_editing.mp4
**System Information** Operating system: Darwin-17.2.0-x86_64-i386-64bit 64 Bits Graphics card: NVIDIA GeForce GTX 1050 Ti OpenGL Engine NVIDIA Corporation 4.1 NVIDIA-10.27.6 378.10.10.10.20.109 **Blender Version** Broken: version: 2.82 (sub 0), branch: master, commit date: 2019-10-16 09:29, hash: `a3f7ae1b96` Worked: (optional) **Short description of error** When you scale around the median point with x axis mirroring enabled, the result is not calculated from the median. **Exact steps for others to reproduce the error** see video. Add circle mesh turn on x axis mirroring (or any other axis) scale around the median It will give an unexpected result (unless you have topology mirror also enabled) This does not work the same as 2.79 (excluding the extra axes of course) [x_axis_mirror_editing.mp4](https://archive.blender.org/developer/F7825618/x_axis_mirror_editing.mp4)
Author
Added subscriber: @WayneDixon
Member
Added subscribers: @mano-wii, @JacquesLucke
Germano Cavalcante was assigned by Jacques Lucke 2019-10-16 15:12:12 +02:00
Member
I can confirm the issue. Looks like not all selected vertices are used to compute the median point.
Assigning to @mano-wii, because it might be caused by 3bd4f229be (haven't tested),
I can confirm the issue. Looks like not all selected vertices are used to compute the median point. Assigning to @mano-wii, because it might be caused by 3bd4f229be (haven't tested),
Germano Cavalcante changed title from Mirror symmetry gives unexpected results to Pivot Center doesn't compute mirror elements 2019-10-16 17:00:43 +02:00
Germano Cavalcante removed their assignment 2019-10-21 16:10:26 +02:00
Campbell Barton was assigned by Germano Cavalcante 2019-10-21 16:10:26 +02:00
Here a less invasive solution to fix this problem.
The idea is to change the TrasData->center of objects with mirror elements.
This changes the behavior of individual origins when the mirrored elements are also selected, but I don't consider it a regression. (The solution may also ignore this particular case).
Solution:
P1145: Idea to fix #70873
diff --git a/source/blender/editors/transform/transform.h b/source/blender/editors/transform/transform.h
index ff2afbc0cd7..4b31931560c 100644
--- a/source/blender/editors/transform/transform.h
+++ b/source/blender/editors/transform/transform.h
@@ -426,6 +426,7 @@ typedef struct TransDataMirror {
   int sign_x : 2;
   int sign_y : 2;
   int sign_z : 2;
+  uint flag : 2;
 } TransDataMirror;
 typedef struct MouseInput {
@@ -825,6 +826,7 @@ enum {
 /** #TransData.flag */
 enum {
   TD_SELECTED = 1 << 0,
+  TD_NOCENTER = 1 << 1,
   TD_NOACTION = 1 << 2,
   TD_USEQUAT = 1 << 3,
   TD_NOTCONNECTED = 1 << 4,
@@ -832,7 +834,6 @@ enum {
   TD_SINGLESIZE = 1 << 5,
   /** Scale relative to individual element center */
   TD_INDIVIDUAL_SCALE = 1 << 8,
-  TD_NOCENTER = 1 << 9,
   /** #TransData.ext abused for particle key timing. */
   TD_NO_EXT = 1 << 10,
   /** don't transform this data */
diff --git a/source/blender/editors/transform/transform_convert_mesh.c b/source/blender/editors/transform/transform_convert_mesh.c
index f1928433491..c0451474281 100644
--- a/source/blender/editors/transform/transform_convert_mesh.c
+++ b/source/blender/editors/transform/transform_convert_mesh.c
@@ -540,6 +540,7 @@ static TransDataMirror *editmesh_mirror_data_calc(BMEditMesh *em,
         mirror_data_iter->sign_x = index- [x] && index- [x]- [x] == -2 ? -1 : 1;
         mirror_data_iter->sign_y = index- [x] && index- [x]- [x] == -2 ? -1 : 1;
         mirror_data_iter->sign_z = index- [x] && index- [x]- [x] == -2 ? -1 : 1;
+        mirror_data_iter->flag = BM_elem_flag_test(eve, BM_ELEM_SELECT) ? TD_SELECTED : 0;
         mirror_data_iter->extra = eve;
         mirror_data_iter++;
@@ -799,6 +800,9 @@ void createTransEditVerts(TransInfo *t)
+    /* Used for mirror only. */
+    uint tod_index = 0;
     BM_ITER_MESH_INDEX (eve, &iter, bm, BM_VERTS_OF_MESH, a) {
       if (BM_elem_flag_test(eve, BM_ELEM_HIDDEN)) {
         continue;
@@ -881,12 +885,40 @@ void createTransEditVerts(TransInfo *t)
           if (tc->mirror.axis_z && fabsf(tob->loc- [x]) < TRANSFORM_MAXDIST_MIRROR) {
             tob->flag |= TD_MIRROR_EDGE_Z;
+          BM_elem_index_set(eve, tod_index);
+          tod_index++;
         tob++;
+    if (tc->mirror.use_mirror_any) {
+      bm->elem_index_dirty |= BM_VERT;
+      /* Change the center of `TransData` elements according to the mirrored elements.
+       * This solves pivot center calculation problems. (See #70873) */
+      TransDataMirror *mirror_data_iter = tc->mirror.data;
+      for (int i = tc->mirror.data_len; i--; mirror_data_iter++) {
+        if ((mirror_data_iter->flag & TD_SELECTED) == 0) {
+          continue;
+        eve = (BMVert *)((char *)mirror_data_iter->loc_src - offsetof(BMVert, co));
+        int tob_index = BM_elem_index_get(eve);
+        tob = &tc->data[tob_index];
+        if (mirror_data_iter->sign_x == -1) {
+          tob->center- [x] = 0.0f;
+        if (mirror_data_iter->sign_y == -1) {
+        if (mirror_data_iter->sign_z == -1) {
     if (island_info) {
       MEM_freeN(island_info);
       MEM_freeN(island_vert_map);
Here a less invasive solution to fix this problem. The idea is to change the `TrasData->center` of objects with mirror elements. This changes the behavior of individual origins when the mirrored elements are also selected, but I don't consider it a regression. (The solution may also ignore this particular case). Solution: [P1145: Idea to fix #70873](https://archive.blender.org/developer/P1145.txt) ```diff diff --git a/source/blender/editors/transform/transform.h b/source/blender/editors/transform/transform.h index ff2afbc0cd7..4b31931560c 100644 --- a/source/blender/editors/transform/transform.h +++ b/source/blender/editors/transform/transform.h @@ -426,6 +426,7 @@ typedef struct TransDataMirror { int sign_x : 2; int sign_y : 2; int sign_z : 2; + uint flag : 2; } TransDataMirror; typedef struct MouseInput { @@ -825,6 +826,7 @@ enum { /** #TransData.flag */ enum { TD_SELECTED = 1 << 0, + TD_NOCENTER = 1 << 1, TD_NOACTION = 1 << 2, TD_USEQUAT = 1 << 3, TD_NOTCONNECTED = 1 << 4, @@ -832,7 +834,6 @@ enum { TD_SINGLESIZE = 1 << 5, /** Scale relative to individual element center */ TD_INDIVIDUAL_SCALE = 1 << 8, - TD_NOCENTER = 1 << 9, /** #TransData.ext abused for particle key timing. */ TD_NO_EXT = 1 << 10, /** don't transform this data */ diff --git a/source/blender/editors/transform/transform_convert_mesh.c b/source/blender/editors/transform/transform_convert_mesh.c index f1928433491..c0451474281 100644 --- a/source/blender/editors/transform/transform_convert_mesh.c +++ b/source/blender/editors/transform/transform_convert_mesh.c @@ -540,6 +540,7 @@ static TransDataMirror *editmesh_mirror_data_calc(BMEditMesh *em, mirror_data_iter->sign_x = index- [x] && index- [x]- [x] == -2 ? -1 : 1; mirror_data_iter->sign_y = index- [x] && index- [x]- [x] == -2 ? -1 : 1; mirror_data_iter->sign_z = index- [x] && index- [x]- [x] == -2 ? -1 : 1; + mirror_data_iter->flag = BM_elem_flag_test(eve, BM_ELEM_SELECT) ? TD_SELECTED : 0; mirror_data_iter->extra = eve; mirror_data_iter++; @@ -799,6 +800,9 @@ void createTransEditVerts(TransInfo *t) } } + /* Used for mirror only. */ + uint tod_index = 0; + BM_ITER_MESH_INDEX (eve, &iter, bm, BM_VERTS_OF_MESH, a) { if (BM_elem_flag_test(eve, BM_ELEM_HIDDEN)) { continue; @@ -881,12 +885,40 @@ void createTransEditVerts(TransInfo *t) if (tc->mirror.axis_z && fabsf(tob->loc- [x]) < TRANSFORM_MAXDIST_MIRROR) { tob->flag |= TD_MIRROR_EDGE_Z; } + + BM_elem_index_set(eve, tod_index); + tod_index++; } tob++; } } + if (tc->mirror.use_mirror_any) { + bm->elem_index_dirty |= BM_VERT; + + /* Change the center of `TransData` elements according to the mirrored elements. + * This solves pivot center calculation problems. (See #70873) */ + TransDataMirror *mirror_data_iter = tc->mirror.data; + for (int i = tc->mirror.data_len; i--; mirror_data_iter++) { + if ((mirror_data_iter->flag & TD_SELECTED) == 0) { + continue; + } + eve = (BMVert *)((char *)mirror_data_iter->loc_src - offsetof(BMVert, co)); + int tob_index = BM_elem_index_get(eve); + tob = &tc->data[tob_index]; + if (mirror_data_iter->sign_x == -1) { + tob->center- [x] = 0.0f; + } + if (mirror_data_iter->sign_y == -1) { + tob->center- [x] = 0.0f; + } + if (mirror_data_iter->sign_z == -1) { + tob->center- [x] = 0.0f; + } + } + } + if (island_info) { MEM_freeN(island_info); MEM_freeN(island_vert_map); ```
Campbell Barton was unassigned by Dalai Felinto 2019-12-23 13:46:47 +01:00
Added subscriber: @ideasman42
This issue was referenced by 1c189aa70a
This issue was referenced by 1c189aa70aff01f72ae1fc2eacefcf924ede62c7
Germano Cavalcante self-assigned this 2020-06-08 13:29:20 +02:00
5 Participants
Reference: blender/blender#70873
