Eevee Intel HD620 broken again in 2.81 (with glitch workaround options batch files)
Closed, DuplicatePublic
I did put this on BlenderArtists.com, but this place worked out a lot the last time I found a bug.
Eevee Glitches are back 2.81 even using the glitch workaround batch file.
However it seems to be a different problem entirely, Because it seems loading a blend file that was made around 2.80 fixes it.
Here is the Debug ouput and system files.
Edit: added version information because woops, you probably need that.
Brad Hawkins (ConsUme) renamed this task from Eevee Intel HD620 broken again (with glitch workaround options batch files) to Eevee Intel HD620 broken again in 2.81 (with glitch workaround options batch files).Thu, Oct 17, 1:46 PM
Brad Hawkins (ConsUme) updated the task description. (Show Details)
Brad Hawkins (ConsUme) added a project: Eevee.
The version of the driver identified is 23.20.16.4973.
But there is already the 26.20.100.7212
