Driver read but not write values to linked objects #70893
2 Participants
Reference: blender/blender#70893
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.15
Broken: version: 2.81 (sub 11), branch: master, commit date: 2019-09-16 21:02, hash:
76650402f3
Setting a value to linked objects works with
or
but not when accessed via driver
Ok, I dont know if this is a limitation , a bug, a missunderstandment from me or a wrong setup as seen in the Image
but
my driver reads the correct value from the linked object "myCube" and I can set the value via Python
I created myCube in a second file
it seems that values of linked objects can be Change with Python and can be read by a Driver but not written
here are the files - myCube has to be in assets Folder reletiv to Main.blend
Main.blend
myCube.blend
Added subscriber: @Masterheavy
Additional:
The Driver connection is lost after closing and reopening the Scene (Main.blend)
Added subscriber: @lichtwerk
From those files, I cannot tell how this is supposed to work:
It is true you can change properties on linked IDs via python (but not permanently, these are lost on file save/reload), but to my knowledge you cannot drive them.
For this to work properly, you need to use the old Proxy System (or the new Library Overrides)
Also you should not read from the same value, add to it and write to it, this will result in dependency cycles.
(it is better to already rig the pass_index in the myCube.blend file with something that can be used as a proxy from the Main.blend, so they dont end up in a dependency cycle)
https://docs.blender.org/manual/en/dev/files/linked_libraries/library_proxies.html
https://docs.blender.org/manual/en/dev/files/linked_libraries/library_overrides.html
If I have not misunderstood something, this sounds like no bug, I think we'll have to close this report (feel free though to comment again if you think I have misunderstood your report -- or if issues persist using the other mentioned methods)
