Diffuse materials glow in corners or small gaps when using Principled Shader in Cycles
Operating system: Linux Mint 19.2
Graphics card: 1080 Ti
Broken: 2.80, cycles
Diffuse materials glow in corners or small gaps when using Principled Shader. I am not sure it is bug or correct behavior, but issue is gone if color value (V from HSV) is decreased to 0.9, or Diffuse shader is used instead. Decreasing roughness and specular also helps but that will make totally different material.
Here are image and blend file
Brecht Van Lommel (brecht) closed this task as Archived.Wed, Nov 6, 4:47 PM
Diffuse materials with reflectivity 1.0 are unrealistic, and this kind of glowing can actually be accurate for the given parameters.
Hm did I miss something - it has roughness 1.0, specular 0.5, metlaness 0.0 - where does reflectivity 1.0 come from?
It's the base color that has 1.0 for some channels.
Here's your original material with a diffuse of HSV 0.5, 0.5, 1.0:
And here's the same scene with diffuse HSV 0.5, 0.5, 0.8:
Ah so essentially pure color is bad to use - I should decrease V to make color little bit darker, thanks ;)
