Annotation: The d-key for annotation not correctly bind in edit mode when using: knife tool, loopcut tool, polybuild, curso tool
Confirmed, NormalPublicBUG
Graphics card: GeForce GTX 550 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 376.51
Broken: version: 2.82 (sub 1), branch: master, commit date: 2019-10-20 07:26, hash: rBfed27c25aa14
  • Go to edit mode try to draw with the d-key down + left mouse drag while one of this tool is selected: knife tool, loopcut tool, polybuild, curso tool
Notice while drawing ( d-key down + left mouse drag )is broken, erase ( d-key down + right mouse drag) is still working properly.
Forgot to mention the real reason D key should be bind while those tools are active, the main reason is when doing retopo, bsurface cannot be used while polybuild is active, those 2 tools are really needed for retopo manually.
This problem seems closely related to the problem described in T70982
I will merge this report to T71164, because it is the same problem, but the areas of influence of these tools are larger.
Richard Antalik (ISS) reopened this task as Confirmed.Jan 15 2020, 3:47 PM
Germano Cavalcante (mano-wii) reopened this task as Confirmed.Feb 13 2020, 4:39 PM
T71164 is not the same bug.
I have checked and the annotation operator is not called because there are some keymap conflict. As the general key for annotations is D. the other keymaps must be changed or we must keep this as a Know issue.
I believe keep this as known issue is a drawback for retopo workflow, and inconsistency since we can still use the shortcut to erase ( with right-select hold the D-key and RMB to erase).
