Software crashes when I click shading tab
Operating system: Windows-8.1-6.3.9600 64 Bits
Graphics card: Intel(R) HD Graphics 4400 Intel 4.2.0 - Build 10.18.10.3621
When ever I click the shading tab the software automatically closes unexpectedly. This is the first I'm using the software since I want to learn animation, but with this software problem it's gonna be a hard to be making models
  1. Open blender
  2. Click the shading tab
IMO this is a duplicate of Intel HD drivers update
Update your GPU drivers from Intel support site can solve/mitigate this problem, you declare to use 10.18.10.xxxx drivers, latest is 15.36.36.xxxx
Before making a new error report, the use of the 'Search' box (top right on the BugTracker Reporting page) is very much appreciated to check if the errors / problems have already been reported by other users, every minute you dedicate at this is a minute earned by the developer to fix bugs. The duplication of the bugreport is a waste of time and resources for the developers
I apologies I won't make the same mistake again, when the next time I report a bug.
Unfortunately the link you send me didn't work (Intel-Driver-and-Support-Assistant-Installer. exe) I tried reinstalling it, run it as administration but nothing happened when ever I click it noting happens
Philipp Oeser (lichtwerk) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Oct 21 2019, 11:25 AM
Please report/solve issues with Intel installers to/with Intel (there is not much we can do here...)
If upgrading the drivers has taken place, please report back if this solved the blender crash, thx.
Sure I'll do that
correct link for you Intel GPU HERE, the other link was generic one to make search into
thank you
I'll probably talk to you later next month, because unfortunately the data on my wifi is nearly finish talk to you later
Brecht Van Lommel (brecht) closed this task as Archived.Wed, Nov 6, 4:25 PM
This is indeed a known issue with these old Intel driver versions, the latest ones are needed.
https://docs.blender.org/manual/en/dev/troubleshooting/gpu/windows/intel.html
Blender 2.81 will also show a warning on startup for this.
