The new version of Blender's macos platform eevee graphics card detected a problem #71013
2 Participants
Reference: blender/blender#71013
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon RX 580 OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.11.20
Broken: version: 2.82 (sub 0), branch: master, commit date: 2019-10-14 19:07, hash:
9a85592dde
Worked: Rendering with eevee
2.81 or 2.80 version is still normal, I use the external gpu on the mac platform and give priority to the external gpu on the program property of the blender, so the eevee rendering is done with the external gpu after opening the blender, 2.82 All this is invalid, eevee can not detect the external gpu, use the built-in intel graphics card to slow down to the stuck unresponsive rendering, please give the macos platform user the last life, no Metal, eevee gpu accelerated rendering is the last hope , please fix this problem or enable eevee to choose rendering device
This does not require any files or steps, find a macbook pro with a Thunderbolt 3 interface to plug in an external graphics card, select “prefer external gpu” in the properties of the Blender program, run the new version and the old version of Blender and use eevee rendering Rendering will know that 2.82 is not using an external graphics card at all.
Added subscriber: @2046411367
Added subscriber: @mano-wii
Is this your external GPU?:
Did you use
Help -> Report a Bug
in Blender to fill in the information in the report?If so, it is very likely that Eevee is using your external GPU.
To make sure, try to run
blender_debug-gpu.cmd
that is included in the download.Render the default cube.
After Blender closes, the logs will be in a text file which can be attached here.
I did not see the download address of the cmd file, even if I saw it, it is useless, because macos can not run the cmd file, I found the command line run method from the Blender manual, the following is the output, I also have the blender output The system-info file is attached.
system-info.txt
/Applications/Blender.app/Contents/MacOS/Blender --debug-gpu
Read prefs: /Users/jinshanhu/Library/Application Support/Blender/2.82/config/userpref.blend
2019-10-23 10:17:31.285 Blender[1163:341668] apply_selection_policy_once: prefer use of removable GPUs (via org.blenderfoundation.blender:GPUSelectionPolicy->preferRemovable)
GPUTexture: create : TEXTURE_CUBE_MAP, RGBA16F, w : 2, h : 2, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 1, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_3D, RGBA8, w : 1, h : 1, d : 1, comp : 4, size : 0.00 MiB
OpenGL debug callback is not available on Apple.
found bundled python: /Applications/Blender.app/Contents/Resources/2.82/python
Registered MESHmachine 0.6.9 with 2 plug libraries
» plug library: Examples
» plug library: MyPlugs
Registered MACHIN3工具(鬼汉化) 0.3.12 with 11 tools, 7 pie menus and 1 context menu
GPUTexture: create : TEXTURE_2D, RGBA8, w : 2155, h : 26, d : 0, comp : 4, size : 0.21 MiB
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 2048, d : 0, comp : 1, size : 32.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 405, h : 26, d : 0, comp : 4, size : 0.04 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 2560, h : 20, d : 0, comp : 4, size : 0.20 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 443, h : 26, d : 0, comp : 4, size : 0.04 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 29, h : 887, d : 0, comp : 4, size : 0.10 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 414, h : 887, d : 0, comp : 4, size : 1.40 MiB
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 4096, d : 0, comp : 1, size : 64.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 443, h : 407, d : 0, comp : 4, size : 0.69 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 2116, h : 26, d : 0, comp : 4, size : 0.21 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 2116, h : 77, d : 0, comp : 4, size : 0.62 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 58, h : 1191, d : 0, comp : 4, size : 0.26 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 2116, h : 1217, d : 0, comp : 4, size : 9.82 MiB
GPUTexture: create : TEXTURE_2D, DEPTH32F_STENCIL8, w : 2116, h : 1217, d : 0, comp : 1, size : 19.65 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 257, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 256, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, R11F_G11F_B10F, w : 2116, h : 1217, d : 0, comp : 3, size : 9.82 MiB
GPUTexture: create : TEXTURE_2D, R32UI, w : 2116, h : 1217, d : 0, comp : 1, size : 9.82 MiB
GPUTexture: create : TEXTURE_2D, RG16, w : 2116, h : 1217, d : 0, comp : 2, size : 9.82 MiB
GPUTexture: create : TEXTURE_2D, RGBA16F, w : 64, h : 64, d : 0, comp : 4, size : 0.06 MiB
GPUTexture: create : TEXTURE_2D, DEPTH_COMPONENT24, w : 2116, h : 1217, d : 0, comp : 1, size : 7.37 MiB
GPUTexture: create : TEXTURE_2D, R16UI, w : 2116, h : 1217, d : 0, comp : 1, size : 4.91 MiB
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 1024, d : 0, comp : 1, size : 16.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 527, h : 491, d : 0, comp : 4, size : 0.99 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 174, h : 73, d : 0, comp : 4, size : 0.05 MiB
Read blend: /Users/jinshanhu/Documents/s gundam.blend
GPUTexture: create : TEXTURE_2D, RGBA8, w : 560, h : 26, d : 0, comp : 4, size : 0.06 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 29, h : 742, d : 0, comp : 4, size : 0.08 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 531, h : 742, d : 0, comp : 4, size : 1.50 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 560, h : 552, d : 0, comp : 4, size : 1.18 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1999, h : 26, d : 0, comp : 4, size : 0.20 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 58, h : 1321, d : 0, comp : 4, size : 0.29 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 236, h : 1321, d : 0, comp : 4, size : 1.19 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1999, h : 1347, d : 0, comp : 4, size : 10.27 MiB
GPUTexture: create : TEXTURE_2D, DEPTH32F_STENCIL8, w : 1999, h : 1347, d : 0, comp : 1, size : 20.54 MiB
GPUTexture: create : TEXTURE_2D, R11F_G11F_B10F, w : 1999, h : 1347, d : 0, comp : 3, size : 10.27 MiB
GPUTexture: create : TEXTURE_2D, R32UI, w : 1999, h : 1347, d : 0, comp : 1, size : 10.27 MiB
GPUTexture: create : TEXTURE_2D, RG16, w : 1999, h : 1347, d : 0, comp : 2, size : 10.27 MiB
GPUTexture: create : TEXTURE_2D, DEPTH_COMPONENT24, w : 1999, h : 1347, d : 0, comp : 1, size : 7.70 MiB
GPUTexture: create : TEXTURE_2D, R16UI, w : 1999, h : 1347, d : 0, comp : 1, size : 5.14 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1440, h : 26, d : 0, comp : 4, size : 0.14 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 59, h : 874, d : 0, comp : 4, size : 0.20 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 221, h : 874, d : 0, comp : 4, size : 0.74 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1440, h : 900, d : 0, comp : 4, size : 4.94 MiB
GPUTexture: create : TEXTURE_2D, DEPTH32F_STENCIL8, w : 1440, h : 900, d : 0, comp : 1, size : 9.89 MiB
GPUTexture: create : TEXTURE_2D, R11F_G11F_B10F, w : 1440, h : 900, d : 0, comp : 3, size : 4.94 MiB
GPUTexture: create : TEXTURE_2D, R32UI, w : 1440, h : 900, d : 0, comp : 1, size : 4.94 MiB
GPUTexture: create : TEXTURE_2D, RG16, w : 1440, h : 900, d : 0, comp : 2, size : 4.94 MiB
GPUTexture: create : TEXTURE_2D, DEPTH_COMPONENT24, w : 1440, h : 900, d : 0, comp : 1, size : 3.71 MiB
GPUTexture: create : TEXTURE_2D, R16UI, w : 1440, h : 900, d : 0, comp : 1, size : 2.47 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 283, h : 122, d : 0, comp : 4, size : 0.13 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 283, h : 100, d : 0, comp : 4, size : 0.11 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1950, h : 26, d : 0, comp : 4, size : 0.19 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1950, h : 1140, d : 0, comp : 4, size : 8.48 MiB
GPUTexture: create : TEXTURE_2D, DEPTH32F_STENCIL8, w : 1950, h : 1140, d : 0, comp : 1, size : 16.96 MiB
GPUTexture: create : TEXTURE_2D, DEPTH32F_STENCIL8, w : 1920, h : 1080, d : 0, comp : 1, size : 15.82 MiB
GPUTexture: create : TEXTURE_2D, RGBA32F, w : 1920, h : 1080, d : 0, comp : 4, size : 63.28 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1920, h : 1080, d : 0, comp : 4, size : 7.91 MiB
GPUTexture: create : TEXTURE_2D, R11F_G11F_B10F, w : 1920, h : 1080, d : 0, comp : 3, size : 7.91 MiB
GPUTexture: create : TEXTURE_2D, RGBA16F, w : 1920, h : 1080, d : 0, comp : 4, size : 31.64 MiB
GPUTexture: create : TEXTURE_2D, RG16I, w : 1920, h : 1080, d : 0, comp : 2, size : 7.91 MiB
GPUTexture: create : TEXTURE_2D, R16F, w : 1920, h : 1080, d : 0, comp : 1, size : 3.96 MiB
GPUTexture: create : TEXTURE_2D, DEPTH_COMPONENT24, w : 960, h : 540, d : 0, comp : 1, size : 1.48 MiB
GPUTexture: create : TEXTURE_2D, RG16, w : 1920, h : 1080, d : 0, comp : 2, size : 7.91 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RGBA16F, w : 64, h : 64, d : 20, comp : 4, size : 1.25 MiB
GPUTexture: create : TEXTURE_1D, RG16F, w : 1024, h : 0, d : 0, comp : 2, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RGBA8, w : 32, h : 32, d : 129, comp : 4, size : 0.50 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, R11F_G11F_B10F, w : 1255, h : 1255, d : 1, comp : 3, size : 6.01 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RGBA8, w : 1, h : 1, d : 1, comp : 4, size : 0.00 MiB
GPUShaderInterface: Warning: Uniform 'attr' not found!
GPUShaderInterface: Warning: Uniform 'colorBuffer' not found!
GPUShaderInterface: Warning: Uniform 'depthBuffer' not found!
GPUShaderInterface: Warning: Uniform 'maxzBuffer' not found!
GPUShaderInterface: Warning: Uniform 'minzBuffer' not found!
GPUShaderInterface: Warning: Uniform 'planarDepth' not found!
GPUShaderInterface: Warning: Uniform 'texHammersley' not found!
GPUShaderInterface: Warning: Uniform 'texJitter' not found!
GPUShaderInterface: Warning: Uniform 'utilTex' not found!
GPUShaderInterface: Warning: Uniform 'horizonBuffer' not found!
GPUShaderInterface: Warning: Uniform 'irradianceGrid' not found!
GPUShaderInterface: Warning: Uniform 'probePlanars' not found!
GPUShaderInterface: Warning: Uniform 'probeCubes' not found!
GPUShaderInterface: Warning: Uniform 'shadowCubeTexture' not found!
GPUShaderInterface: Warning: Uniform 'shadowCascadeTexture' not found!
GPUShaderInterface: Warning: Uniform 'inScattering' not found!
GPUShaderInterface: Warning: Uniform 'inTransmittance' not found!
GPUTexture: create : TEXTURE_3D, R8, w : 1, h : 1, d : 1, comp : 1, size : 0.00 MiB
GPUShaderInterface: Warning: Uniform 'hairPointBuffer' not found!
GPUShaderInterface: Warning: Uniform 'hairUVBuffer' not found!
GPUShaderInterface: Warning: Uniform 'hairColBuffer' not found!
GPUTexture: create : TEXTURE_1D, RGBA16F, w : 64, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, DEPTH_COMPONENT24, w : 2050, h : 2050, d : 54, comp : 1, size : 649.27 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, DEPTH_COMPONENT24, w : 4096, h : 4096, d : 1, comp : 1, size : 48.00 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, DEPTH_COMPONENT24, w : 1, h : 1, d : 1, comp : 1, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 29, h : 768, d : 0, comp : 4, size : 0.08 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 531, h : 768, d : 0, comp : 4, size : 1.56 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 560, h : 571, d : 0, comp : 4, size : 1.22 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 58, h : 1366, d : 0, comp : 4, size : 0.30 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 236, h : 1366, d : 0, comp : 4, size : 1.23 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1999, h : 1392, d : 0, comp : 4, size : 10.61 MiB
GPUTexture: create : TEXTURE_2D, DEPTH32F_STENCIL8, w : 1999, h : 1392, d : 0, comp : 1, size : 21.23 MiB
GPUTexture: create : TEXTURE_2D, R11F_G11F_B10F, w : 1999, h : 1392, d : 0, comp : 3, size : 10.61 MiB
GPUTexture: create : TEXTURE_2D, R32UI, w : 1999, h : 1392, d : 0, comp : 1, size : 10.61 MiB
GPUTexture: create : TEXTURE_2D, RG16, w : 1999, h : 1392, d : 0, comp : 2, size : 10.61 MiB
GPUTexture: create : TEXTURE_2D, DEPTH_COMPONENT24, w : 1999, h : 1392, d : 0, comp : 1, size : 7.96 MiB
GPUTexture: create : TEXTURE_2D, R16UI, w : 1999, h : 1392, d : 0, comp : 1, size : 5.31 MiB
I have experienced another breakdown just now. This is the error reported by macos. I don't know if there is any help.
Process: Blender [1221]
Path: /Applications/Blender.app/Contents/MacOS/Blender
Identifier: Blender
Version: 2.82 (2.82 2019-10-15)
Code Type: X86-64 (Native)
Parent Process: bash [1088]
Responsible: Blender [1221]
User ID: 501
Date/Time: 2019-10-23 10:31:23.502 +0800
OS Version: Mac OS X 10.14.6 (18G95)
Report Version: 12
Anonymous UUID: E85DF158-CFC7-0945-F3CB-9B72A3139B5F
Time Awake Since Boot: 4200 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
ID Vend/Dev
7005 67df1002
Seconds Ago ID Type
4200.0 7005 Attach
Application Specific Information:
abort() called
Blender(1221,0x1248655c0) malloc: Incorrect checksum for freed object 0x7fd367cf7640: probably modified after being freed.
Corrupt value: 0xf00007fd3625cf00
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff5f1f72c6 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff5f2b2bf1 pthread_kill + 284
2 libsystem_c.dylib 0x00007fff5f161745 __abort + 144
3 libsystem_c.dylib 0x00007fff5f1616b5 abort + 142
4 libsystem_malloc.dylib 0x00007fff5f270077 malloc_vreport + 545
5 libsystem_malloc.dylib 0x00007fff5f288e0d malloc_zone_error + 183
6 libsystem_malloc.dylib 0x00007fff5f26c84b tiny_free_list_remove_ptr + 544
7 libsystem_malloc.dylib 0x00007fff5f269fef tiny_free_no_lock + 377
8 libsystem_malloc.dylib 0x00007fff5f269d79 free_tiny + 480
9 com.apple.AppKit 0x00007fff3084a7a8 -[NSRegion dealloc] + 63
10 com.apple.AppKit 0x00007fff309cd489 -[NSWindow dealloc] + 2614
11 com.apple.AppKit 0x00007fff30e1ce32 -[_NSWindowExitFullScreenTransitionController dealloc] + 47
12 libobjc.A.dylib 0x00007fff5d8e347c (anonymous namespace)::AutoreleasePoolPage::pop(void*) + 710
13 com.apple.CoreFoundation 0x00007fff331105ea _CFAutoreleasePoolPop + 22
14 com.apple.CoreFoundation 0x00007fff3313da23 __CFRunLoopRun + 2323
15 com.apple.CoreFoundation 0x00007fff3313cebe CFRunLoopRunSpecific + 455
16 com.apple.HIToolbox 0x00007fff3239c1ab RunCurrentEventLoopInMode + 292
17 com.apple.HIToolbox 0x00007fff3239bded ReceiveNextEventCommon + 355
18 com.apple.HIToolbox 0x00007fff3239bc76 _BlockUntilNextEventMatchingListInModeWithFilter + 64
19 com.apple.AppKit 0x00007fff3073479d _DPSNextEvent + 1135
20 com.apple.AppKit 0x00007fff3073348b -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361
21 org.blenderfoundation.blender 0x000000011239d00e GHOST_SystemCocoa::processEvents(bool) + 238
22 org.blenderfoundation.blender 0x0000000112394c36 GHOST_ProcessEvents + 22
23 org.blenderfoundation.blender 0x000000010e02b1a8 wm_window_process_events + 24
24 org.blenderfoundation.blender 0x000000010dffc7c8 WM_main + 24
25 org.blenderfoundation.blender 0x000000010daf1b2f main + 927
26 libdyld.dylib 0x00007fff5f0bc3d5 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fff5f1f486a __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff5f2b356e _pthread_cond_wait + 722
2 libc++.1.dylib 0x00007fff5c2eea0a std::__1::condition_variable::wait(std::__1::unique_lockstd::__1::mutex&) + 18
3 org.blenderfoundation.blender 0x000000010f171063 IlmThread_2_3::Semaphore::wait() + 147
4 org.blenderfoundation.blender 0x000000010f16e5c2 IlmThread_2_3::(anonymous namespace)::DefaultWorkerThread::run() + 66
5 org.blenderfoundation.blender 0x000000010f170ab7 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_deletestd::__1::__thread_struct >, void (IlmThread_2_3::Thread::)(), IlmThread_2_3::Thread> >(void*) + 663
6 libsystem_pthread.dylib 0x00007fff5f2b02eb _pthread_body + 126
7 libsystem_pthread.dylib 0x00007fff5f2b3249 _pthread_start + 66
8 libsystem_pthread.dylib 0x00007fff5f2af40d thread_start + 13
Thread 2:
Thread 3:
Thread 4:
Thread 5:
0 libsystem_pthread.dylib 0x00007fff5f2af3f0 start_wqthread + 0
Thread 6:: Dispatch queue: NSPersistentUI Work
0 libsystem_kernel.dylib 0x00007fff5f1f39de __ulock_wait + 10
1 libsystem_platform.dylib 0x00007fff5f2a5c3a _os_unfair_lock_lock_slow + 143
2 libsystem_malloc.dylib 0x00007fff5f269c42 free_tiny + 169
3 libsystem_blocks.dylib 0x00007fff5f105bf3 _Block_release + 105
4 libdispatch.dylib 0x00007fff5f06f63d _dispatch_client_callout + 8
5 libdispatch.dylib 0x00007fff5f0758e0 _dispatch_lane_serial_drain + 602
6 libdispatch.dylib 0x00007fff5f076396 _dispatch_lane_invoke + 385
7 libdispatch.dylib 0x00007fff5f07e6ed _dispatch_workloop_worker_thread + 598
8 libsystem_pthread.dylib 0x00007fff5f2af611 _pthread_wqthread + 421
9 libsystem_pthread.dylib 0x00007fff5f2af3fd start_wqthread + 13
Thread 7:
Thread 8:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff5f1f122a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff5f1f176c mach_msg + 60
2 com.apple.audio.CoreAudio 0x00007fff32badeda HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 122
3 com.apple.audio.CoreAudio 0x00007fff32bade4f HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 45
4 com.apple.audio.CoreAudio 0x00007fff32baa39f HALC_ProxyIOContext::IOWorkLoop() + 1017
5 com.apple.audio.CoreAudio 0x00007fff32ba9df4 HALC_ProxyIOContext::IOThreadEntry(void*) + 122
6 com.apple.audio.CoreAudio 0x00007fff32ba9956 HALB_IOThread::Entry(void*) + 72
7 libsystem_pthread.dylib 0x00007fff5f2b02eb _pthread_body + 126
8 libsystem_pthread.dylib 0x00007fff5f2b3249 _pthread_start + 66
9 libsystem_pthread.dylib 0x00007fff5f2af40d thread_start + 13
Thread 9:
Thread 10:
2 org.blenderfoundation.blender 0x000000010ddd652c task_scheduler_thread_run + 172
3 libsystem_pthread.dylib 0x00007fff5f2b02eb _pthread_body + 126
4 libsystem_pthread.dylib 0x00007fff5f2b3249 _pthread_start + 66
5 libsystem_pthread.dylib 0x00007fff5f2af40d thread_start + 13
Thread 11:
Thread 12:
Thread 13:: com.apple.NSEventThread
2 com.apple.CoreFoundation 0x00007fff3313e1ee __CFRunLoopServiceMachPort + 328
3 com.apple.CoreFoundation 0x00007fff3313d75c __CFRunLoopRun + 1612
4 com.apple.CoreFoundation 0x00007fff3313cebe CFRunLoopRunSpecific + 455
5 com.apple.AppKit 0x00007fff3073c4c2 _NSEventThread + 175
Thread 14:
Thread 0 crashed with X86 Thread State (64-bit):
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x10d9a7000 - 0x11565cf07 +org.blenderfoundation.blender (2.82 - 2.82 2019-10-15) <6163D148-31D4-3978-9B68-7C2BD562648C> /Applications/Blender.app/Contents/MacOS/Blender
0x11aaf8000 - 0x11ab59ff7 +libomp.dylib (0) /Applications/Blender.app/Contents/Resources/lib/libomp.dylib
0x11b8bc000 - 0x11b8c0ffb com.apple.audio.AppleHDAHALPlugIn (282.54 - 282.54) <207D25F0-B094-3569-AA6D-09B4EDD72861> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x11b8f5000 - 0x11b8f9ffb com.apple.audio.AppleGFXHDAHALPlugIn (100.1.414 - 100.1.414) <8C81D6E5-9975-3FE1-841A-AFC9FCB87630> /System/Library/Extensions/AppleGFXHDA.kext/Contents/PlugIns/AppleGFXHDAHALPlugIn.bundle/Contents/MacOS/AppleGFXHDAHALPlugIn
0x11c200000 - 0x11c395fff com.apple.audio.units.Components (1.14 - 1.14) <8B1DABE8-8F96-364D-9C60-36B06CD73466> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x11f7aa000 - 0x11f7abfff +_queue.cpython-37m-darwin.so (0) <199A1B17-D720-3353-A0B2-F129AA7F0CBD> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_queue.cpython-37m-darwin.so
0x11f82f000 - 0x11f842fff +_pickle.cpython-37m-darwin.so (0) <41D595B2-7CCC-3D5D-9C9D-FE19E2A4F194> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_pickle.cpython-37m-darwin.so
0x11f84e000 - 0x11f857fff +_socket.cpython-37m-darwin.so (0) <37855193-A377-309C-B959-4345EB9DC8EB> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_socket.cpython-37m-darwin.so
0x11f864000 - 0x11f86afff +array.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/array.cpython-37m-darwin.so
0x11f8b4000 - 0x11f8c7ff7 +zlib.cpython-37m-darwin.so (0) <0A105F1F-8E36-3A50-B031-5E6A74897959> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/zlib.cpython-37m-darwin.so
0x11f8cd000 - 0x11f8e3ffb +_bz2.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_bz2.cpython-37m-darwin.so
0x11f8e9000 - 0x11f917ff3 +_lzma.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_lzma.cpython-37m-darwin.so
0x11f921000 - 0x11f921ffb +grp.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/grp.cpython-37m-darwin.so
0x11f924000 - 0x11f925ff3 +_multiprocessing.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_multiprocessing.cpython-37m-darwin.so
0x11f969000 - 0x11fb2a267 +_ssl.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_ssl.cpython-37m-darwin.so
0x11fc00000 - 0x11fc06ff7 +binascii.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/binascii.cpython-37m-darwin.so
0x11fcca000 - 0x11fcd8ff3 +_datetime.cpython-37m-darwin.so (0) <01B8C0DC-88FE-3832-BA52-1F587D87B03A> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_datetime.cpython-37m-darwin.so
0x11fd64000 - 0x11fe62ffb +unicodedata.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/unicodedata.cpython-37m-darwin.so
0x11ff83000 - 0x11ff83ff3 +_scproxy.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_scproxy.cpython-37m-darwin.so
0x11ff87000 - 0x11ff87ff3 +_uuid.cpython-37m-darwin.so (0) <1185618F-988E-3C12-A792-158CD33445DC> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_uuid.cpython-37m-darwin.so
0x1218fb000 - 0x1218fe047 libobjc-trampolines.dylib (756.2) <5795A048-3940-3801-90CE-33D1B1AF81F4> /usr/lib/libobjc-trampolines.dylib
0x121bf1000 - 0x121cbaff7 com.apple.AMDRadeonX4000GLDriver (2.11.20 - 2.1.1) <0AD1C812-DBC2-3949-82E6-7DAEE291ED76> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0x1246eb000 - 0x1246f0ff7 +math.cpython-37m-darwin.so (0) <020CD697-A524-3D7F-91F9-F650FDBCCEAF> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/math.cpython-37m-darwin.so
0x1247b7000 - 0x1247b7ff7 +_heapq.cpython-37m-darwin.so (0) <00765882-48C7-335D-B1CE-766B4AD04AEB> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_heapq.cpython-37m-darwin.so
0x1247bb000 - 0x1247bbffb +_bisect.cpython-37m-darwin.so (0) <7DF2E4D8-9831-3079-850F-141A9D90FEE6> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_bisect.cpython-37m-darwin.so
0x1247be000 - 0x1247bffff +_posixsubprocess.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_posixsubprocess.cpython-37m-darwin.so
0x1247c3000 - 0x12482d70f dyld (655.1.1) /usr/lib/dyld
0x125a2b000 - 0x125a2eff7 +select.cpython-37m-darwin.so (0) <5CCA5A20-0D42-3391-885F-9AE521B40F2C> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/select.cpython-37m-darwin.so
0x127f10000 - 0x127f4efff +_decimal.cpython-37m-darwin.so (0) <01A9D36B-0F97-38E7-B1CB-3C16AFB895DF> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_decimal.cpython-37m-darwin.so
0x128353000 - 0x128357ff7 +_struct.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_struct.cpython-37m-darwin.so
0x1283a0000 - 0x12850c19f +_hashlib.cpython-37m-darwin.so (0) <6B908184-1671-308E-92A6-244C4B38A99C> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_hashlib.cpython-37m-darwin.so
0x12857f000 - 0x128585ff3 +_blake2.cpython-37m-darwin.so (0) <1A1B51B5-03B2-3BEB-B1C6-ED59934F12F0> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_blake2.cpython-37m-darwin.so
0x12858a000 - 0x12859bff3 +_sha3.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_sha3.cpython-37m-darwin.so
0x1285a1000 - 0x1285a2ffb +_random.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_random.cpython-37m-darwin.so
0x128767000 - 0x12876dfff +_json.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_json.cpython-37m-darwin.so
0x128944000 - 0x128c98ff7 +_multiarray_umath.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/core/_multiarray_umath.cpython-37m-darwin.so
0x128f56000 - 0x128f63ff7 +_multiarray_tests.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/core/_multiarray_tests.cpython-37m-darwin.so
0x128f72000 - 0x128f84fff +_ctypes.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/lib-dynload/_ctypes.cpython-37m-darwin.so
0x129032000 - 0x129033fff +lapack_lite.cpython-37m-darwin.so (0) <1A662C20-37F0-30B3-9E40-5E8C240E069C> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/linalg/lapack_lite.cpython-37m-darwin.so
0x129037000 - 0x129050ffb +_umath_linalg.cpython-37m-darwin.so (0) <63291FB6-DD38-3D47-BC11-4FFFAC1C4349> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/linalg/_umath_linalg.cpython-37m-darwin.so
0x12911e000 - 0x12912ffff +pocketfft_internal.cpython-37m-darwin.so (0) <93CB80ED-4101-3595-8757-D0AF6E249862> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/fft/pocketfft_internal.cpython-37m-darwin.so
0x1291b3000 - 0x12921aff3 +mtrand.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/random/mtrand.cpython-37m-darwin.so
0x12926c000 - 0x12929bff3 +common.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/random/common.cpython-37m-darwin.so
0x1292b0000 - 0x129301ffb +bounded_integers.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/random/bounded_integers.cpython-37m-darwin.so
0x129324000 - 0x129337ff7 +mt19937.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/random/mt19937.cpython-37m-darwin.so
0x129343000 - 0x129361fff +bit_generator.cpython-37m-darwin.so (0) <025128BF-E246-32A2-AFEF-1CE175F8E165> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/random/bit_generator.cpython-37m-darwin.so
0x12937c000 - 0x12939eff7 +entropy.cpython-37m-darwin.so (0) <4752D9DC-8652-3B2E-B488-FE36F08BACF7> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/random/entropy.cpython-37m-darwin.so
0x1293b4000 - 0x12942bfff +generator.cpython-37m-darwin.so (0) <8E8AF1A9-5B53-37C9-B662-9A0C2AB127ED> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/random/generator.cpython-37m-darwin.so
0x12947d000 - 0x129487ff3 +pcg64.cpython-37m-darwin.so (0) <3B8A71E9-ADD4-34F0-9A70-4EAB2F6C1C0D> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/random/pcg64.cpython-37m-darwin.so
0x129492000 - 0x12949eff3 +philox.cpython-37m-darwin.so (0) <81EC089B-7EE4-3F5B-89DE-ABEF0A635272> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/random/philox.cpython-37m-darwin.so
0x1294aa000 - 0x1294b1ff7 +sfc64.cpython-37m-darwin.so (0) <5E31C52F-0E46-39F8-ACE2-E291ABF4FAAC> /Applications/Blender.app/Contents/Resources/2.82/python/lib/python3.7/site-packages/numpy/random/sfc64.cpython-37m-darwin.so
0x7fff27bc0000 - 0x7fff27cccfff com.apple.AMDMTLBronzeDriver (2.11.20 - 2.1.1) <1D8E8E3B-88F4-35B1-8E83-AE74B558C26C> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x7fff27ccd000 - 0x7fff28672ff3 ATIRadeonX4000SCLib.dylib (2.11.20) <13C8B1DC-87F9-3F99-88E8-F7719F98D99E> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x7fff2d7af000 - 0x7fff2dae0ff7 com.apple.driver.AppleIntelSKLGraphicsMTLDriver (12.10.12 - 12.1.0) /System/Library/Extensions/AppleIntelSKLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelSKLGraphicsMTLDriver
0x7fff2f4e6000 - 0x7fff2f4e6fff com.apple.Accelerate (1.11 - Accelerate 1.11) <762942CB-CFC9-3A0C-9645-A56523A06426> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff2f4e7000 - 0x7fff2f4fdff7 libCGInterfaces.dylib (506.22) <1B6C92D9-F4B8-37BA-9635-94C4A56098CE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff2f4fe000 - 0x7fff2fb97fef com.apple.vImage (8.1 - ???) <53FA3611-894E-3158-A654-FBD2F70998FE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff2fb98000 - 0x7fff2fe11ff3 libBLAS.dylib (1243.200.4) <417CA0FC-B6CB-3FB3-ACBC-8914E3F62D20> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff2fe12000 - 0x7fff2fe84ffb libBNNS.dylib (38.250.1) <538D12A2-9B9D-3E22-9896-F90F6E69C06E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff2fe85000 - 0x7fff3022eff3 libLAPACK.dylib (1243.200.4) <92175DF4-863A-3780-909A-A3E5C410F2E9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff3022f000 - 0x7fff30244feb libLinearAlgebra.dylib (1243.200.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff30245000 - 0x7fff3024aff3 libQuadrature.dylib (3.200.2) <1BAE7E22-2862-379F-B334-A3756067730F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff3024b000 - 0x7fff302c7ff3 libSparse.dylib (79.200.5) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff302c8000 - 0x7fff302dbfe3 libSparseBLAS.dylib (1243.200.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff302dc000 - 0x7fff304c3ff7 libvDSP.dylib (671.250.4) <7B110627-A9C1-3FB7-A077-0C7741BA25D8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff304c4000 - 0x7fff30577ff7 libvMisc.dylib (671.250.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff30578000 - 0x7fff30578fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <74288115-EF61-30B6-843F-0593B31D4929> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff3071a000 - 0x7fff314cfffb com.apple.AppKit (6.9 - 1671.60.107) <2F7E5984-E89A-3451-A3DF-FAAA509CF884> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff31521000 - 0x7fff31521fff com.apple.ApplicationServices (50.1 - 50.1) <84097DEB-E2FC-3901-8DD7-A670EA2274E0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff31522000 - 0x7fff3158dfff com.apple.ApplicationServices.ATS (377 - 453.11.2.2) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff31626000 - 0x7fff3173dfff libFontParser.dylib (228.6.2.3) <3602D55B-3B9E-3B3A-A814-08C1244A8AE4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff3173e000 - 0x7fff31780fff libFontRegistry.dylib (228.12.2.3) <2A56347B-2809-3407-A8B4-2AB88E484062> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff317da000 - 0x7fff3180cfff libTrueTypeScaler.dylib (228.6.2.3) <7E4C5D9C-51AF-3EC1-8FA5-11CD4BEE477A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff31871000 - 0x7fff31875ff3 com.apple.ColorSyncLegacy (4.13.0 - 1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff31910000 - 0x7fff31962ff7 com.apple.HIServices (1.22 - 628) <2BE461FF-80B9-30D3-A574-AED5724B1C1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff31963000 - 0x7fff31972fff com.apple.LangAnalysis (1.7.0 - 1.7.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff31973000 - 0x7fff319bcff7 com.apple.print.framework.PrintCore (14.2 - 503.8) <57C2FE32-0E74-3079-B626-C2D52F2D2717> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff319bd000 - 0x7fff319f6ff7 com.apple.QD (3.12 - 407.2) <28C7D39F-59C9-3314-BECC-67045487229C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff319f7000 - 0x7fff31a03fff com.apple.speech.synthesis.framework (8.1.3 - 8.1.3) <5E7B9BD4-122B-3012-A044-3259C97E7509> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff31a04000 - 0x7fff31c7bff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <04F482F1-E1C1-3955-8A6C-8AA152AA06F3> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff31c7d000 - 0x7fff31c7dfff com.apple.audio.units.AudioUnit (1.14 - 1.14) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff31fd6000 - 0x7fff32377fff com.apple.CFNetwork (978.0.7 - 978.0.7) /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff3238c000 - 0x7fff3238cfff com.apple.Carbon (158 - 158) <56AD06AA-7BB4-3F0B-AEF7-9768D0BC1C98> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff3238d000 - 0x7fff32390ffb com.apple.CommonPanels (1.2.6 - 98) <1CD6D56D-8EC7-3528-8CBC-FC69533519B5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff32391000 - 0x7fff32688fff com.apple.HIToolbox (2.1.1 - 918.7) <13F69D4C-D19F-3E09-9231-1978D783A556> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff32689000 - 0x7fff3268cff3 com.apple.help (1.3.8 - 66) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff3268d000 - 0x7fff32692ff7 com.apple.ImageCapture (9.0 - 1534.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff32693000 - 0x7fff32728ff3 com.apple.ink.framework (10.9 - 225) <7C7E9483-2E91-3DD3-B1E0-C238F42CA0DD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff32729000 - 0x7fff32741ff7 com.apple.openscripting (1.7 - 179.1) <9B8C1ECC-5864-3E21-9149-863E884EA25C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff32761000 - 0x7fff32762ff7 com.apple.print.framework.Print (14.2 - 267.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff32763000 - 0x7fff32765ff7 com.apple.securityhi (9.0 - 55006) <05717F77-7A7B-37E6-AB3E-03F063E9095B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff32766000 - 0x7fff3276cff7 com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <3CC050FB-EBCB-3087-8EA5-F378C8F99217> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff3288e000 - 0x7fff3288efff com.apple.Cocoa (6.11 - 23) <8D092DD2-0CA4-34C9-872C-8BBFAE1995A4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff3289c000 - 0x7fff329ebff7 com.apple.ColorSync (4.13.0 - 3345.6) <31648BB6-7239-3D0E-81B1-BCF51FEF557F> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff32b77000 - 0x7fff32bfdfff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <1E8E64E6-0E58-375A-97F7-07CB4EE181AC> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff32c61000 - 0x7fff32c8bffb com.apple.CoreBluetooth (1.0 - 1) /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff32c8c000 - 0x7fff33011fef com.apple.CoreData (120 - 866.6) <132CB39B-8D58-30FA-B8AD-49BFFF34B293> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff33012000 - 0x7fff33102ff7 com.apple.CoreDisplay (101.3 - 110.18) <0EB2A997-FCAD-3D17-B140-9829961E5327> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff33103000 - 0x7fff33547fe7 com.apple.CoreFoundation (6.9 - 1575.19) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff33549000 - 0x7fff33bd8fff com.apple.CoreGraphics (2.0 - 1265.9) /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff33bda000 - 0x7fff33efafff com.apple.CoreImage (14.4.0 - 750.0.140) <11026E39-D2FF-3CF6-8ACE-7BA293F9853E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff34358000 - 0x7fff34358fff com.apple.CoreServices (946 - 946) <6EC9F377-EBD8-3358-92D1-6586F6F1E8E9> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff34359000 - 0x7fff343d5ff7 com.apple.AE (773 - 773) <55AE7C9E-27C3-30E9-A047-3B92A6FD53B4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff343d6000 - 0x7fff346adfff com.apple.CoreServices.CarbonCore (1178.33 - 1178.33) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff346ae000 - 0x7fff346f6ff7 com.apple.DictionaryServices (1.2 - 284.16.4) <746EB200-DC51-30AE-9CBC-608A7B4CC8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff346f7000 - 0x7fff346ffffb com.apple.CoreServices.FSEvents (1239.200.12 - 1239.200.12) <8406D379-8D33-3611-861B-7ABD26DB50D2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff34700000 - 0x7fff348b1ff7 com.apple.LaunchServices (946 - 946) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff348b2000 - 0x7fff34950ff7 com.apple.Metadata (10.7.0 - 1191.57) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff34951000 - 0x7fff3499bff7 com.apple.CoreServices.OSServices (946 - 946) <20C4EEF8-D5AC-39A0-9B4A-78F88E3EFBCC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff3499c000 - 0x7fff34a03ff7 com.apple.SearchKit (1.4.0 - 1.4.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff34a04000 - 0x7fff34a25ff3 com.apple.coreservices.SharedFileList (71.28 - 71.28) <487A8464-729E-305A-B5D1-E3FE8EB9CFC5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff34d30000 - 0x7fff34e92ff3 com.apple.CoreText (352.0 - 584.26.3.2) <59919B0C-CBD5-3877-8D6F-D6048F1E5F42> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff34e93000 - 0x7fff34ed3ff3 com.apple.CoreVideo (1.8 - 281.4) <10CF8E52-07E3-382B-8091-2CEEEFFA69B4> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff34ed4000 - 0x7fff34f63fff com.apple.framework.CoreWLAN (13.0 - 1375.2) /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff351ba000 - 0x7fff351bfffb com.apple.DiskArbitration (2.7 - 2.7) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff35382000 - 0x7fff35384ff3 com.apple.ForceFeedback (1.0.6 - 1.0.6) <205B0C3E-4E8D-3347-A993-469F06ABBFF9> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
0x7fff35385000 - 0x7fff35732ffb com.apple.Foundation (6.9 - 1575.19) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff357a1000 - 0x7fff357d0ffb com.apple.GSS (4.0 - 2.0) /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff358d0000 - 0x7fff359dafff com.apple.Bluetooth (6.0.14 - 6.0.14d3) /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff35a3d000 - 0x7fff35accfff com.apple.framework.IOKit (2.0.2 - 1483.260.4) <8A90F547-86EF-3DFB-92FE-0E2C0376DD84> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff35ace000 - 0x7fff35addffb com.apple.IOSurface (255.6.1 - 255.6.1) <85F85EBB-EA59-3A8B-B3EB-7C20F3CC77AE> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff35b31000 - 0x7fff35cbcfef com.apple.ImageIO.framework (3.3.0 - 1850.2) <75E46A31-D87D-35CE-86A4-96A50971FDB2> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff35cbd000 - 0x7fff35cc1ffb libGIF.dylib (1850.2) <4774EBDF-583B-3DDD-A0E1-9F427CB6A074> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff35cc2000 - 0x7fff35d9efef libJP2.dylib (1850.2) <697BB77F-A682-339F-8659-35432962432D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff35d9f000 - 0x7fff35dc4feb libJPEG.dylib (1850.2) <171A8AC4-AADA-376F-9F2C-B9C978DB1007> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff36087000 - 0x7fff360adfeb libPng.dylib (1850.2) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff360ae000 - 0x7fff360b0ffb libRadiance.dylib (1850.2) <56907025-D5CE-3A9E-ACCB-A376C2599853> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff360b1000 - 0x7fff360fefe7 libTIFF.dylib (1850.2) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff37271000 - 0x7fff3728afff com.apple.Kerberos (3.0 - 1) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff37ca6000 - 0x7fff37d4eff7 com.apple.Metal (162.2 - 162.2) /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff37d6a000 - 0x7fff37d89ff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <44CE8362-E972-3697-AD6F-15BC863BAEB8> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff37d8a000 - 0x7fff37e06fe7 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff37e07000 - 0x7fff37e2efff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff37e2f000 - 0x7fff37f5aff7 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff37f5b000 - 0x7fff37f75fff com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff37f76000 - 0x7fff37f77ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <69F14BCF-C5C5-3BF8-9C31-8F87D2D6130A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff38d6e000 - 0x7fff38d7aff7 com.apple.NetFS (6.0 - 4.0) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff390dd000 - 0x7fff39100ff7 com.apple.audio.OpenAL (1.8 - 1.8) <2EE5236C-775B-36B1-97A8-DEE5FB80F5B5> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x7fff3b80f000 - 0x7fff3b817fe3 libcldcpuengine.dylib (2.11) /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff3b818000 - 0x7fff3b86fff7 com.apple.opencl (2.15.3 - 2.15.3) <056BAD8A-23BC-3F74-9E2C-3AC81E7DEA5A> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff3b870000 - 0x7fff3b88bff7 com.apple.CFOpenDirectory (10.14 - 207.200.4) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff3b88c000 - 0x7fff3b897ffb com.apple.OpenDirectory (10.14 - 207.200.4) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff3c1e7000 - 0x7fff3c1e9fff libCVMSPluginSupport.dylib (17.7.3) <8E051EA7-55B6-3DF1-9821-72C391DE953B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff3c1ea000 - 0x7fff3c1efff3 libCoreFSCache.dylib (166.2) <222C2A4F-7E32-30F6-8459-2FAB98073A3D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff3c1f0000 - 0x7fff3c1f4fff libCoreVMClient.dylib (166.2) <6789ECD4-91DD-32EF-A1FD-F27D2344CD8B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff3c1f5000 - 0x7fff3c1fdff7 libGFXShared.dylib (17.7.3) <8C50BF27-B525-3B23-B86C-F444ADF97851> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff3c1fe000 - 0x7fff3c209fff libGL.dylib (17.7.3) <2AC457EA-1BD3-3C8E-AFAB-7EA6234EB749> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff3c20a000 - 0x7fff3c244fef libGLImage.dylib (17.7.3) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff3c245000 - 0x7fff3c3b7ff7 libGLProgrammability.dylib (17.7.3) <5BB795C6-97AB-37AC-954C-145E3216AC3B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff3c3b8000 - 0x7fff3c3f6fff libGLU.dylib (17.7.3) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff3cd93000 - 0x7fff3cda2ffb com.apple.opengl (17.7.3 - 17.7.3) <94B5CF34-5BD6-3652-9A8C-E9C56E0A9FB4> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff3cda3000 - 0x7fff3cf3aff7 GLEngine (17.7.3) /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff3cf3b000 - 0x7fff3cf64ff3 GLRendererFloat (17.7.3) /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff3dba5000 - 0x7fff3ddfcff7 com.apple.QuartzCore (1.11 - 701.14) <33E846BE-1794-3186-9BF2-6ADF62C782A3> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff3e632000 - 0x7fff3e932fff com.apple.security (7.0 - 58286.270.3.0.1) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff3e933000 - 0x7fff3e9bffff com.apple.securityfoundation (6.0 - 55185.260.1) <1EE899E6-222A-3526-B505-B0D0B6FA042A> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff3e9f1000 - 0x7fff3e9f5fff com.apple.xpc.ServiceManagement (1.0 - 1) /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff3ed8e000 - 0x7fff3edfbfff com.apple.SystemConfiguration (1.17 - 1.17) <30C8327F-3EFF-3520-9C50-016F8B6B954F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff42037000 - 0x7fff420dcfeb com.apple.APFS (1.0 - 1) <2D22485D-552D-3CB6-9FE1-38547597918F> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff42af1000 - 0x7fff42af2ff7 com.apple.AggregateDictionary (1.0 - 1) /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff430f3000 - 0x7fff4311fff7 com.apple.framework.Apple80211 (13.0 - 1380.2) <16F093EF-370B-3B90-8DB4-E94624431D15> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff43247000 - 0x7fff43256fc7 com.apple.AppleFSCompression (96.200.3 - 1.0) <3CF60CE8-976E-3CB8-959D-DD0948C1C2DE> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff43352000 - 0x7fff4335dfff com.apple.AppleIDAuthSupport (1.0 - 1) <2E9D1398-DBE6-328B-ADDA-20FA5FAD7405> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff4339e000 - 0x7fff433e7ff3 com.apple.AppleJPEG (1.0 - 1) <4C1F426B-7D77-3980-9633-7DBD8C666B9A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff4363b000 - 0x7fff4365dfff com.apple.applesauce (1.0 - ???) /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff437bc000 - 0x7fff437d0ffb com.apple.AssertionServices (1.0 - 1) <456E507A-4561-3628-9FBE-173ACE7429D8> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff43b9f000 - 0x7fff43c8bff7 com.apple.AuthKit (1.0 - 1) <2765ABE9-54F2-3E45-8A93-1261E251B90D> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff43e4d000 - 0x7fff43e55fff com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <2A396FC0-7B79-3088-9A82-FB93C1181A57> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff43e56000 - 0x7fff43eebfff com.apple.backup.framework (1.10.5 - ???) <4EEC51E2-AE4C-340A-B686-901810152C12> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff43eec000 - 0x7fff43f59ff3 com.apple.BaseBoard (360.28 - 360.28) <68FA8044-F3CD-3BC6-9DAB-27DACF52BFC0> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff45bc4000 - 0x7fff45bcdffb com.apple.CommonAuth (4.0 - 2.0) <93335CB6-ABEB-3EC7-A040-8A667F40D5F3> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff468a6000 - 0x7fff468b7ff7 com.apple.CoreEmoji (1.0 - 69.19.9) <228457B3-E191-356E-9A5B-3C0438D05FBA> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff46e61000 - 0x7fff46ec7ff7 com.apple.CoreNLP (1.0 - 130.15.22) <27877820-17D0-3B02-8557-4014E876CCC7> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff47174000 - 0x7fff4717cff7 com.apple.CorePhoneNumbers (1.0 - 1) <11F97C7E-C183-305F-8E6C-9B374F50E26B> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff472f8000 - 0x7fff47329ff3 com.apple.CoreServicesInternal (358 - 358) /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff476f0000 - 0x7fff47774fff com.apple.CoreSymbolication (10.2 - 64490.25.1) <28B2FF2D-3FDE-3A20-B343-341E5BD4E22F> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff47804000 - 0x7fff4792fff7 com.apple.coreui (2.1 - 499.10) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff47930000 - 0x7fff47ad0fff com.apple.CoreUtils (5.9 - 590.16) <66CC50F7-766D-33E2-A388-4DE22840ADFB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff47b24000 - 0x7fff47b87ff7 com.apple.framework.CoreWiFi (13.0 - 1375.2) /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff47b88000 - 0x7fff47b99ff7 com.apple.CrashReporterSupport (10.13 - 938.26) /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff47c29000 - 0x7fff47c38fff com.apple.framework.DFRFoundation (1.0 - 211.1) /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff47c39000 - 0x7fff47c3dff7 com.apple.DSExternalDisplay (3.1 - 380) <787B9748-B120-3453-B8FE-61D9E363A9E0> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff47cbe000 - 0x7fff47d33ffb com.apple.datadetectorscore (7.0 - 590.27) <06FB1A07-7AE6-3ADD-8E7E-41955FAB38E8> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff47d7f000 - 0x7fff47dbcff7 com.apple.DebugSymbols (190 - 190) <6F4FAACA-E06B-38AD-A0C2-14EA5408A231> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff47dbd000 - 0x7fff47ef8ff7 com.apple.desktopservices (1.13.5 - ???) <265C0E94-B8BF-3F58-8D68-EA001EEA0B15> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff48e3f000 - 0x7fff4925afff com.apple.vision.FaceCore (3.3.4 - 3.3.4) /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff4cb0e000 - 0x7fff4cb0ffff libmetal_timestamp.dylib (902.3.2) <05389463-AF2E-33E2-A14F-1416E4A30835> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff4e1a3000 - 0x7fff4e1aeff7 libGPUSupportMercury.dylib (17.7.3) <36E3C5B1-15EB-3713-BC3A-31A3B074DD24> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff4e1af000 - 0x7fff4e1b4fff com.apple.GPUWrangler (3.50.12 - 3.50.12) <6C820ED9-F306-3978-B5B8-432AD97BBDAF> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff4efc0000 - 0x7fff4efcffff com.apple.GraphVisualizer (1.0 - 5) <48D020B7-5938-3FAE-B468-E291AEE2C06F> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff4f135000 - 0x7fff4f1a9ffb com.apple.Heimdal (4.0 - 2.0) /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff504a5000 - 0x7fff504aefff com.apple.IOAccelMemoryInfo (1.0 - 1) /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff504af000 - 0x7fff504b6ffb com.apple.IOAccelerator (404.14 - 404.14) <11A50171-C8AE-3BBC-9FB9-2A3313FFBD31> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff504ba000 - 0x7fff504d2fff com.apple.IOPresentment (1.0 - 42.6) <6DFD9A6E-BF95-3A27-89E7-ACAA9E30D90A> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff5087a000 - 0x7fff508a7ff7 com.apple.IconServices (379 - 379) <7BAD562D-4FA3-3E11-863C-1EEBE2406D2C> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff50b3a000 - 0x7fff50b4cff3 com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <30CFE05C-4108-3879-AFAA-5BB02CBE190B> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff50b67000 - 0x7fff50c42ff7 com.apple.LanguageModeling (1.0 - 159.15.15) <3DE3CE61-542B-37B7-883E-4B9717CAC65F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff50c43000 - 0x7fff50c7fff7 com.apple.Lexicon-framework (1.0 - 33.15.10) <4B5E843E-2809-3E70-9560-9254E2656419> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff50c86000 - 0x7fff50c8bfff com.apple.LinguisticData (1.0 - 238.25) /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff51980000 - 0x7fff519a8ff7 com.apple.spotlight.metadata.utilities (1.0 - 1191.57) <38BB1FB7-3336-384C-B71F-4D0D402EB606> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff519a9000 - 0x7fff51a36ff7 com.apple.gpusw.MetalTools (1.0 - 1) /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff51c06000 - 0x7fff51c21ffb com.apple.MobileKeyBag (2.0 - 1.0) /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff51caa000 - 0x7fff51cd4ffb com.apple.MultitouchSupport.framework (2450.1 - 2450.1) <42A23EC9-64A7-31C7-BF33-DF4412ED8A3F> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff51f10000 - 0x7fff51f1afff com.apple.NetAuth (6.2 - 6.2) <0D01BBE5-0269-310D-B148-D19DAE143DEB> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff5277b000 - 0x7fff527ccff3 com.apple.OTSVG (1.0 - ???) <5BF1A9EB-2694-3267-9514-A4EB3BEF4081> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff53964000 - 0x7fff53973ff7 com.apple.PerformanceAnalysis (1.218.2 - 218.2) <65F3DB3E-6D4E-33A0-B510-EF768D323DAB> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff55805000 - 0x7fff55823ff7 com.apple.ProtocolBuffer (1 - 263.2) <907D6C95-D50-31DE-99CA-16A5135BC6F9> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff559bb000 - 0x7fff55a0bfff com.apple.ROCKit (27.6 - 27.6) <756C2253-E8B1-3C48-9945-DE8D6AD24DE2> /System/Library/PrivateFrameworks/ROCKit.framework/Versions/A/ROCKit
0x7fff55b69000 - 0x7fff55b8bfff com.apple.RemoteViewServices (2.0 - 128) <8FB0E4EB-DCBB-32E6-94C6-AA9BA9EE4CAC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff57395000 - 0x7fff574b3fff com.apple.Sharing (1288.62 - 1288.62) <48B1F247-7910-3C16-814C-B99DE231F7F0> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff582c7000 - 0x7fff58576fff com.apple.SkyLight (1.600.0 - 340.54) <90EB1C2E-B264-3EC4-AF7F-CDE7E7585746> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff58d19000 - 0x7fff58d25fff com.apple.SpeechRecognitionCore (5.0.21 - 5.0.21) <7A6A67DB-C813-328E-AAFB-D267A5B50B3D> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff59476000 - 0x7fff59501fc7 com.apple.Symbolication (10.2 - 64490.38.1) <9FDCC98D-5B32-35AD-A9BF-94DF2B78507F> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff599e9000 - 0x7fff599f5ffb com.apple.TCC (1.0 - 1) <73CF6FA9-44CE-30C9-887F-235940976585> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff59c5b000 - 0x7fff59d23ff3 com.apple.TextureIO (3.8.4 - 3.8.1) <7CEAC05A-D283-3D5A-B1E3-C849285FA0BF> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff59dd9000 - 0x7fff59ddafff com.apple.TrustEvaluationAgent (2.0 - 31.200.1) <15DF9C73-54E4-3C41-BCF4-378338C55FB4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff59de0000 - 0x7fff59f97ffb com.apple.UIFoundation (1.0 - 551.2) <917480B5-14BE-30E0-ABE6-9702336CC35A> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff5ac13000 - 0x7fff5acecfff com.apple.ViewBridge (401.1 - 401.1) <18144EC1-5DEF-369C-8EBA-2826E7142784> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff5b4c4000 - 0x7fff5b4c7fff com.apple.dt.XCTTargetBootstrap (1.0 - 14490.66) <7AE3457F-AF40-3508-93FB-1D9E31EB1C9D> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff5b8c8000 - 0x7fff5b8caffb com.apple.loginsupport (1.0 - 1) <3F8D6334-BCD6-36C1-BA20-CC8503A84375> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff5bb94000 - 0x7fff5bbc8fff libCRFSuite.dylib (41.15.4) <406DAC06-0C77-3F90-878B-4D38F11F0256> /usr/lib/libCRFSuite.dylib
0x7fff5bbcb000 - 0x7fff5bbd5ff7 libChineseTokenizer.dylib (28.15.3) <9B7F6109-3A5D-3641-9A7E-31D2239D73EE> /usr/lib/libChineseTokenizer.dylib
0x7fff5bc63000 - 0x7fff5bc64ffb libDiagnosticMessagesClient.dylib (107) /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff5bc9b000 - 0x7fff5bef2ff3 libFosl_dynamic.dylib (18.3.4) <1B5DD4E2-8AE0-315E-829E-D5BFCD264EA8> /usr/lib/libFosl_dynamic.dylib
0x7fff5bf43000 - 0x7fff5bf62fff libMobileGestalt.dylib (645.270.1) <99A06C8A-97D6-383D-862C-F453BABB48A4> /usr/lib/libMobileGestalt.dylib
0x7fff5bf63000 - 0x7fff5bf63fff libOpenScriptingUtil.dylib (179.1) <4D603146-EDA5-3A74-9FF8-4F75D8BB9BC6> /usr/lib/libOpenScriptingUtil.dylib
0x7fff5c0a3000 - 0x7fff5c0a4ffb libSystem.B.dylib (1252.250.1) /usr/lib/libSystem.B.dylib
0x7fff5c120000 - 0x7fff5c121fff libThaiTokenizer.dylib (2.15.1) /usr/lib/libThaiTokenizer.dylib
0x7fff5c133000 - 0x7fff5c149ffb libapple_nghttp2.dylib (1.24.1) <6F04250A-6686-3FDC-9A8D-290C64B06502> /usr/lib/libapple_nghttp2.dylib
0x7fff5c14a000 - 0x7fff5c173ffb libarchive.2.dylib (54.250.1) <47289946-8504-3966-9127-6CE39993DC2C> /usr/lib/libarchive.2.dylib
0x7fff5c174000 - 0x7fff5c1f3fff libate.dylib (1.13.8) <92B44EDB-369D-3EE8-AEC5-61F8B9313DBF> /usr/lib/libate.dylib
0x7fff5c1f7000 - 0x7fff5c1f7ff3 libauto.dylib (187) <3E3780E1-96F3-3A22-91C5-92F9A5805518> /usr/lib/libauto.dylib
0x7fff5c2c7000 - 0x7fff5c2d7ffb libbsm.0.dylib (39.200.18) /usr/lib/libbsm.0.dylib
0x7fff5c2d8000 - 0x7fff5c2e5fff libbz2.1.0.dylib (38.200.3) <272953A1-8D36-329B-BDDB-E887B347710F> /usr/lib/libbz2.1.0.dylib
0x7fff5c2e6000 - 0x7fff5c339ff7 libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib
0x7fff5c33a000 - 0x7fff5c34fff7 libc++abi.dylib (400.17) <38C09CED-9090-3719-90F3-04A2749F5428> /usr/lib/libc++abi.dylib
0x7fff5c350000 - 0x7fff5c350ff3 libcharset.1.dylib (51.200.6) <2A27E064-314C-359C-93FC-8A9B06206174> /usr/lib/libcharset.1.dylib
0x7fff5c351000 - 0x7fff5c361ffb libcmph.dylib (6.15.1) <9C52B2FE-179F-32AC-B87E-2AFC49ABF817> /usr/lib/libcmph.dylib
0x7fff5c362000 - 0x7fff5c37affb libcompression.dylib (52.250.2) <7F4BB18C-1FB4-3825-8D8B-6E6B168774C6> /usr/lib/libcompression.dylib
0x7fff5c5ef000 - 0x7fff5c605fff libcoretls.dylib (155.220.1) <4C64BE3E-41E3-3020-8BB7-07E90C0C861C> /usr/lib/libcoretls.dylib
0x7fff5c606000 - 0x7fff5c607ff3 libcoretls_cfhelpers.dylib (155.220.1) <0959B3E9-6643-3589-8BB3-21D52CDF0EF1> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff5c7a5000 - 0x7fff5c89dff7 libcrypto.35.dylib (22.260.1) <91C3D71A-4D1D-331D-89CC-67863DF10574> /usr/lib/libcrypto.35.dylib
0x7fff5cab3000 - 0x7fff5cb09ff3 libcups.2.dylib (462.12) <095619DC-9233-3937-9E50-5F10D917A40D> /usr/lib/libcups.2.dylib
0x7fff5cc3d000 - 0x7fff5cc3dfff libenergytrace.dylib (17.200.1) <80BB567A-FD18-3497-BF97-353F57D98CDD> /usr/lib/libenergytrace.dylib
0x7fff5cc6f000 - 0x7fff5cc74ff7 libgermantok.dylib (17.15.2) /usr/lib/libgermantok.dylib
0x7fff5cc75000 - 0x7fff5cc7aff7 libheimdal-asn1.dylib (520.270.1) <73F60D6F-76F8-35EF-9C86-9A81225EE4BE> /usr/lib/libheimdal-asn1.dylib
0x7fff5cca5000 - 0x7fff5cd95fff libiconv.2.dylib (51.200.6) <2047C9B7-3F74-3A95-810D-2ED8F0475A99> /usr/lib/libiconv.2.dylib
0x7fff5cd96000 - 0x7fff5cff7ffb libicucore.A.dylib (62141.0.1) /usr/lib/libicucore.A.dylib
0x7fff5d044000 - 0x7fff5d045fff liblangid.dylib (128.15.1) <22D05C4F-769B-3075-ABCF-44A0EBACE028> /usr/lib/liblangid.dylib
0x7fff5d046000 - 0x7fff5d05eff3 liblzma.5.dylib (10.200.3) /usr/lib/liblzma.5.dylib
0x7fff5d076000 - 0x7fff5d11aff7 libmecab.1.0.0.dylib (779.24.1) /usr/lib/libmecab.1.0.0.dylib
0x7fff5d11b000 - 0x7fff5d31ffff libmecabra.dylib (779.24.1) /usr/lib/libmecabra.dylib
0x7fff5d4f7000 - 0x7fff5d848ff7 libnetwork.dylib (1229.250.15) <72C7E9E3-B2BE-3300-BE1B-64606222022C> /usr/lib/libnetwork.dylib
0x7fff5d8da000 - 0x7fff5e05ffdf libobjc.A.dylib (756.2) <7C312627-43CB-3234-9324-4DEA92D59F50> /usr/lib/libobjc.A.dylib
0x7fff5e071000 - 0x7fff5e075ffb libpam.2.dylib (22.200.1) <586CF87F-349C-393D-AEEB-FB75F94A5EB7> /usr/lib/libpam.2.dylib
0x7fff5e078000 - 0x7fff5e0adfff libpcap.A.dylib (79.250.1) /usr/lib/libpcap.A.dylib
0x7fff5e1c6000 - 0x7fff5e1deffb libresolv.9.dylib (65.200.2) <893142A5-F153-3437-A22D-407EE542B5C5> /usr/lib/libresolv.9.dylib
0x7fff5e231000 - 0x7fff5e40efff libsqlite3.dylib (274.26) <6404BA3B-BCA4-301F-B2FE-8776105A2AA3> /usr/lib/libsqlite3.dylib
0x7fff5e627000 - 0x7fff5e62aff7 libutil.dylib (51.200.4) /usr/lib/libutil.dylib
0x7fff5e62b000 - 0x7fff5e638fff libxar.1.dylib (417.1) <39CCF46B-C81A-34B1-92A1-58C4E5DA846E> /usr/lib/libxar.1.dylib
0x7fff5e63d000 - 0x7fff5e71fff3 libxml2.2.dylib (32.10) /usr/lib/libxml2.2.dylib
0x7fff5e720000 - 0x7fff5e748ff3 libxslt.1.dylib (16.5) /usr/lib/libxslt.1.dylib
0x7fff5e749000 - 0x7fff5e75bff7 libz.1.dylib (70.200.4) /usr/lib/libz.1.dylib
0x7fff5ef3f000 - 0x7fff5ef43ff3 libcache.dylib (81) <1987D1E1-DB11-3291-B12A-EBD55848E02D> /usr/lib/system/libcache.dylib
0x7fff5ef44000 - 0x7fff5ef4eff3 libcommonCrypto.dylib (60118.250.2) <1765BB6E-6784-3653-B16B-CB839721DC9A> /usr/lib/system/libcommonCrypto.dylib
0x7fff5ef4f000 - 0x7fff5ef56ff7 libcompiler_rt.dylib (63.4) <5212BA7B-B7EA-37B4-AF6E-AC4F507EDFB8> /usr/lib/system/libcompiler_rt.dylib
0x7fff5ef57000 - 0x7fff5ef60ff7 libcopyfile.dylib (146.250.1) <98CD00CD-9B91-3B5C-A9DB-842638050FA8> /usr/lib/system/libcopyfile.dylib
0x7fff5ef61000 - 0x7fff5efe5fc3 libcorecrypto.dylib (602.260.2) <01464D24-570C-3B83-9D18-467769E0FCDD> /usr/lib/system/libcorecrypto.dylib
0x7fff5f06c000 - 0x7fff5f0a5ff7 libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib
0x7fff5f0a6000 - 0x7fff5f0d2ff7 libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib
0x7fff5f0d3000 - 0x7fff5f0d3ffb libkeymgr.dylib (30) <0D0F9CA2-8D5A-3273-8723-59987B5827F2> /usr/lib/system/libkeymgr.dylib
0x7fff5f0d4000 - 0x7fff5f0e0ff3 libkxld.dylib (4903.271.2) /usr/lib/system/libkxld.dylib
0x7fff5f0e1000 - 0x7fff5f0e1ff7 liblaunch.dylib (1336.261.2) <2B07E27E-D404-3E98-9D28-BCA641E5C479> /usr/lib/system/liblaunch.dylib
0x7fff5f0e2000 - 0x7fff5f0e7fff libmacho.dylib (927.0.3) /usr/lib/system/libmacho.dylib
0x7fff5f0e8000 - 0x7fff5f0eaffb libquarantine.dylib (86.220.1) <6D0BC770-7348-3608-9254-F7FFBD347634> /usr/lib/system/libquarantine.dylib
0x7fff5f0eb000 - 0x7fff5f0ecff7 libremovefile.dylib (45.200.2) <9FBEB2FF-EEBE-31BC-BCFC-C71F8D0E99B6> /usr/lib/system/libremovefile.dylib
0x7fff5f0ed000 - 0x7fff5f104ff3 libsystem_asl.dylib (356.200.4) /usr/lib/system/libsystem_asl.dylib
0x7fff5f105000 - 0x7fff5f105ff7 libsystem_blocks.dylib (73) /usr/lib/system/libsystem_blocks.dylib
0x7fff5f106000 - 0x7fff5f18dfff libsystem_c.dylib (1272.250.1) <7EDACF78-2FA3-35B8-B051-D70475A35117> /usr/lib/system/libsystem_c.dylib
0x7fff5f18e000 - 0x7fff5f191ffb libsystem_configuration.dylib (963.270.3) <2B4A836D-68A4-33E6-8D48-CD4486B03387> /usr/lib/system/libsystem_configuration.dylib
0x7fff5f192000 - 0x7fff5f195ff7 libsystem_coreservices.dylib (66) <719F75A4-74C5-3BA6-A09E-0C5A3E5889D7> /usr/lib/system/libsystem_coreservices.dylib
0x7fff5f196000 - 0x7fff5f19cfff libsystem_darwin.dylib (1272.250.1) /usr/lib/system/libsystem_darwin.dylib
0x7fff5f19d000 - 0x7fff5f1a3ff7 libsystem_dnssd.dylib (878.270.2) /usr/lib/system/libsystem_dnssd.dylib
0x7fff5f1a4000 - 0x7fff5f1efffb libsystem_info.dylib (517.200.9) /usr/lib/system/libsystem_info.dylib
0x7fff5f1f0000 - 0x7fff5f218ff7 libsystem_kernel.dylib (4903.271.2) /usr/lib/system/libsystem_kernel.dylib
0x7fff5f219000 - 0x7fff5f264ff7 libsystem_m.dylib (3158.200.7) /usr/lib/system/libsystem_m.dylib
0x7fff5f265000 - 0x7fff5f28ffff libsystem_malloc.dylib (166.270.1) <011F3AD0-8E6A-3A89-AE64-6E5F6840F30A> /usr/lib/system/libsystem_malloc.dylib
0x7fff5f290000 - 0x7fff5f29aff7 libsystem_networkextension.dylib (767.250.2) /usr/lib/system/libsystem_networkextension.dylib
0x7fff5f29b000 - 0x7fff5f2a2fff libsystem_notify.dylib (172.200.21) <145B5CFC-CF73-33CE-BD3D-E8DDE268FFDE> /usr/lib/system/libsystem_notify.dylib
0x7fff5f2a3000 - 0x7fff5f2acfef libsystem_platform.dylib (177.270.1) <9D1FE5E4-EB7D-3B3F-A8D1-A96D9CF1348C> /usr/lib/system/libsystem_platform.dylib
0x7fff5f2ad000 - 0x7fff5f2b7ff7 libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib
0x7fff5f2b8000 - 0x7fff5f2bbff7 libsystem_sandbox.dylib (851.270.1) <9494594B-5199-3186-82AB-5FF8BED6EE16> /usr/lib/system/libsystem_sandbox.dylib
0x7fff5f2bc000 - 0x7fff5f2beff3 libsystem_secinit.dylib (30.260.2) /usr/lib/system/libsystem_secinit.dylib
0x7fff5f2bf000 - 0x7fff5f2c6ff3 libsystem_symptoms.dylib (820.267.1) <03F1C2DD-0F5A-3D9D-88F6-B26C0F94EB52> /usr/lib/system/libsystem_symptoms.dylib
0x7fff5f2c7000 - 0x7fff5f2dcfff libsystem_trace.dylib (906.260.1) /usr/lib/system/libsystem_trace.dylib
0x7fff5f2de000 - 0x7fff5f2e3ffb libunwind.dylib (35.4) <24A97A67-F017-3CFC-B0D0-6BD0224B1336> /usr/lib/system/libunwind.dylib
0x7fff5f2e4000 - 0x7fff5f313fff libxpc.dylib (1336.261.2) <7DEE2300-6D8E-3C00-9C63-E3E80D56B0C4> /usr/lib/system/libxpc.dylib
External Modification Summary:
VM Region Summary:
ReadOnly portion of Libraries: Total=559.8M resident=0K(0%) swapped_out_or_unallocated=559.8M(100%)
Writable regions: Total=373.6M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=373.6M(100%)
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 2
Activity Tracing 256K 1
CG backing stores 1432K 4
CG image 88K 12
CoreAnimation 136K 17
CoreGraphics 8K 1
CoreImage 40K 6
CoreUI image data 756K 10
CoreUI image file 404K 3
Dispatch continuations 8192K 1
Foundation 4K 1
Kernel Alloc Once 8K 1
MALLOC 289.8M 158
MALLOC guard page 32K 7
MALLOC_LARGE (reserved) 384K 3 reserved VM address space (unallocated)
Memory Tag 242 12K 1
Memory Tag 249 156K 2
OpenGL GLSL 256K 3
STACK GUARD 56.1M 15
Stack 15.1M 16
VM_ALLOCATE 56.8M 161
__DATA 118.0M 305
__FONT_DATA 4K 1
__GLSLBUILTINS 5176K 1
__LINKEDIT 256.9M 52
__TEXT 302.9M 297
__UNICODE 564K 1
mapped file 56.5M 20
shared memory 672K 8
TOTAL 1.1G 1110
TOTAL, minus reserved VM space 1.1G 1110
Model: MacBookPro13,1, BootROM 240.0.0.0.0, 2 processors, Intel Core i5, 2 GHz, 8 GB, SMC 2.36f98
Graphics: kHW_IntelIrisGraphics540Item, Intel Iris Graphics 540, spdisplays_builtin
Graphics: Radeon RX 580, Radeon RX 580, spdisplays_pcie_device, 8 GB
Memory Module: BANK 0/DIMM0, 4 GB, LPDDR3, 1867 MHz, 0x802C, 0x4D5435324C3531324D3332443250462D3130
Memory Module: BANK 1/DIMM0, 4 GB, LPDDR3, 1867 MHz, 0x802C, 0x4D5435324C3531324D3332443250462D3130
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x159), Broadcom BCM43xx 1.0 (7.77.61.2 AirPortDriverBrcmNIC-1305.8)
Bluetooth: Version 6.0.14d3, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
PCI Card: Radeon RX 580, Display Controller, Thunderbolt@133,0,0
PCI Card: pci1002,aaf0, Audio Device, Thunderbolt@133,0,1
USB Device: USB 3.0 Bus
USB Device: USB2.0 Hub
USB Device: USB 2.0 Hub
USB Device: USB Keyboard
USB Device: USB Receiver
USB Device: USB2.1 Hub
USB Device: BillBoard
USB Device: USB 10/100/1000 LAN
USB Device: USB3.0 Hub
USB Device: Mass Storage Device
USB Device: BUP RD
USB Device: USB3.1 Hub
USB Device: Live Streaming USB Device
Thunderbolt Bus: MacBook Pro, Apple Inc., 41.1
Thunderbolt Device: AKiTiO Node, inXtron, 3, 25.1
No matter what, if eevee really uses rx580, it is Eevee serious performance degradation on the macos platform, and the same rendering settings of 2.80 under the 2.82 eevee rendering, I can't even operate anything, all stuck, only Force the end of the thread. The same is true for eevee preview rendering, and the view mode of look dev is almost impossible to operate.
If the problem is a performance regression, then it is better to do another report showing this regression (so I can poke a qualified developer for a look).
Try to copy texts with technical information into a .txt files
I can't tell if it's performance degradation or device detection. Where can I get more technical information for you?
This depends on what the assigned developer in the other report needs.
FXA-08GB G-Core.blend This project file is opened in macos version blender to preview in eevee mode, there will be serious performance degradation, the number of frames for playing animation will even be reduced to single digits, but the number of eevee viewport frames will return to normal after holding the middle mouse button for a few seconds. , Becomes very smooth, once you release the middle button to move the viewport again, it will freeze again.
