FBX Import Selection
Open, Needs Triage by DeveloperPublic
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
FBX file format doesn't work for Import, or export even when it is selected in preferences!
STL  file format doesn't work for Import, or export even when it is selected in preferences!
3DS  file format doesn't work for Import, or export even when it is selected in preferences!
DXF  file format doesn't work for Import, or export even when it is selected in preferences!
OBJ  file format doesn't work for Import, or export even when it is selected in preferences!
X3D  file format doesn't work for Import, or export even when it is selected in preferences!
Reloaded the Blender 2.8 software and attempted the same operation several times with no different results.  Also tried the same using 2.79, but the model created in 2.8 would not load in 2.79.
