Bake with Cage fails when target mesh has a modifier and is in a different scene to the Cage #71065
Reference: blender/blender#71065
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 417.35
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash:
f6cb5f5449
When a mesh has a modifier on it and is used as a bake target with a Cage object and that Cage object is in a different scene (but has the same modifier), the bake will fail reporting that the objects do not have the same number of sides. When the Cage and target are in the same scene it works as expected.
Also, separate to this issue but connected: The Cage object will have its Render visibility left disabled after bake (regardless of success or failure) when ever its not in the same scene.
It will say that the cage is invalid as the objects have different number of sides. If you now check back in the first scene, the Cube there will have had its Render visibility turned off.
Now delete or disable for render the mirror modifier on the target cube and repeat the bake. It will now work, even though the cage still has the modifier (it should NOT work in this configuration). The Cage object will again have its Render visibility disabled regardless of its starting state.
I have attached a simple demo broken_cage_bake.blend with three scenes:
1)base scene - has all objects in it and works as expected.
2)broken - has a Cube with mirror mod and a Cone with the Cube from scene 1 set as cage, shows error.
3)working - same scene as 2, but mirror mod is removed. Look at base scene after bake and see how the cage has been left hidden for render. Note that while this works, it shouldn't be working and should report that the meshs don't match!
Added subscriber: @JerahmyPocott
Added subscriber: @mano-wii
Changed status from 'Confirmed' to: 'Needs User Info'
Is this still a problem in the latest builds?
https://builder.blender.org/download/
I cannot reproduce the problem.
But I probably misunderstood the steps to reproduce it.
Added subscriber: @Blendify
Changed status from 'Needs User Info' to: 'Resolved'
