Simplify F-Curves unusable because panel is not adjustable #71099
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#71099
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
Can't use panel to adjust the 'Distance Error', which makes it not usable at all.
Added subscriber: @bart.hesselmann
Added subscriber: @lichtwerk
Cannot reproduce here [once the
Simplify Curves+
Addon is enabled, and channels with keyframes are selected, I can execute the operator and change the value in the REDO panel/headsup display]Have you checked this with a fresh build from https://builder.blender.org?
Could you also check this with Factory Settings and just that Addon enabled?
I don't know what was the case but a simple restart of the program seemed to work. Sorry for the confusion.
I guess we can can close this then.
(feel free to comment again if issues persist)
Added subscriber: @ChristophWerner
Tested in Blender 2.80
I've a small medaillon, that is just 10 centimeters wide. There is a small animated bird inside.
The simplify curve doesn't work, even when I set an error value of "0.00001".
The result: The curves are completely cleaned and became nearly straight lines after simplifying them.
All works fine with big sized objects in meters. So there seem to be a problem with the decimal places value.
It's just working, when I use the search bar and execute it from there manually.
EDIT: I've verified it. I've scaled my object 10 times as big, and all worked then.
So please correct this great tool to use it with very tiny models too. Animation curves can't be scaled proportionally, while objects are scaled as I know.
Thank you
A chance for a fix within the next future? See my post above, please.
Thank you
Chris
@ChristophWerner: Could you please report this in a new, fresh report?
(it is not practical having multiple issues in one report, thx)
Of course:
1st: #71655
2nd: #71656
