Blenderkit: asset bar doesnt open #71204
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#71204
Operating system: Windows 10
Graphics card: AMD FirePro M4000
This is a work laptop
Broken: 2.80
Worked: never, installed for first time 9/16
Asset bar doesn't open search results are 0
Added subscriber: @Zelaira
Added subscriber: @Mets
Could you clarify what addon this relates to?
Edit: I see, Blenderkit Asset Library. But I think you forgot to attach the screenshot you mentioned?
Added subscriber: @VilemDuha
Trying to search for addon authors names on phabricator, CC @VilemDuha Can you take a look at this?
not sure why it didn't attach before. it seems the error cuts off at the end as it just says "(caused by" if there's a way to pull the whole error message let me know.
Even though this addon comes with blender when you install it may be this is something that I need to talk to the Blenderkit guys over? When I clicked "report a bug" in the preferences it sent me here.
asset bar doesnt opento Blenderkit: asset bar doesnt openThis is correctly reported here, and thanks for the report.
However, it seems like a possible firewall issue, or something else with the connection. BlenderKit uses the requests library, which simply uses default system settings to access web through https protocol. So basically the same as any web browser.
If you want to get the whole report, use window > Toggle system console, and there a longer output can be copy-pasted from.
Added subscriber: @lichtwerk
@Zelaira: waiting for the console output @VilemDuha was talking about...
Added subscriber: @Blendify
Changed status from 'Needs User Info' to: 'Resolved'
