X3D Import does not handle Materials #71232
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
12 Participants
Reference: blender/blender-addons#71232
Operating system: Windows 10
Graphics card: GT 1070
Broken: 2.90, 0330d1af29c0
When an X3D file is imported and that file has a Material tag no corresponding material is added in blender. Materials are supported for other formats like OBJ.
Example:
red-cube.x3d
red-cube.blend
Material import was more or less disabled in
e8da70ab73
Added subscriber: @jose.xavier
#81519 was marked as duplicate of this issue
blender/blender#81437 was marked as duplicate of this issue
Added subscriber: @lichtwerk
Hi there and thx for the report (sorry this has been lying around).
Possibly normals are inverted, but to really investigate, could you share one of those .wrl files so we can check?
Added subscriber: @easyw
@lichtwerk
you can test any of the KiCAD 3D model wrl files...
I used to import those files in Blender and it worked fine till 2.7.9
With Blender 2.8 the wrl just loses colors.
(tested with blender-2.81a-linux-glibc217-x86_64)
i.e. you can try this file
https://github.com/KiCad/kicad-packages3D/raw/master/Capacitor_SMD.3dshapes/CP_Elec_10x10.5.wrl
or
https://raw.githubusercontent.com/KiCad/kicad-packages3D/master/Capacitor_Tantalum_SMD.3dshapes/CP_EIA-7343-30_AVX-N.wrl
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscriber: @adammak
The cause of that is return in 2699th line of code in import_x3d.py which returns the method. Moreover, the color vectors need alpha value to be added.
I submitted bug, there is temporary fix you can use:
Added subscriber: @ankitm
Added subscriber: @mont29
Note that proper solution would be to add support for shader nodes, but that is a fairly big project...
Added subscriber: @khavin
Any update on this? It may be something else, but I'm still experiencing the lack of colors on 2.90.1 running on Windows 10 2004. The .wrl was generated by KiCAD 5.1.6.
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
Import WRL shows no colorto X3D Import does not handle MaterialsAdded subscriber: @the_magnet_girl
Added subscriber: @Justin.kedl
Added subscriber: @marioamb
Added subscriber: @jr-br
Thanks a lot for this workaround, @adammak!
I fixed two little issues for myself when I applied it, one is that your code assigened diff_color to bymat.specular_color instead of spec_color, and the second is that that field does not seem to like the alpha value:
... which makes it:
I am currently using Blender 2.90.1.
Added subscriber: @RigoLigo
I tried to port
appearance_CreateMaterial
andappearance_CreateDefaultMaterial
to shader nodes and seem to work fine. I'll see if I can submit the patch after taking some time refining it...Basically tuple size can be solved by expanding it with
(*diff_color, 1.0)
;By setting
bpymat.use_nodes
toTrue
enables node tree, then you can modify the nodes with something likebpymat.node_tree.nodes['Principled BSDF'].inputs['Base Color'].default_value = (*diff_color, 1.0)
.Haven't tried to port image textures yet, but should be pretty trivial to add, as linking node tree is also simple.
This issue was referenced by
0573bc7dae
