volumetric lighting origin showing through objects in 2.81 #71271
Reference: blender/blender#71271
Graphics card: Quadro P4000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.70
Broken: version: 2.81 (sub 14), branch: master, commit date: 2019-10-07 20:16, hash:
a856c5eccf
Worked: 2.8 doesn't have the issue
area light behind panel you can see the point of the volumetric generation option_volumtric_issue1.blend
open attached blend file i've attached an image and circled the issue
in addition is there anyway to have area lights not just have volumetrics at the center point? if it was generated from the whole panel of the area light that would be amazingly helpful in making it look more realistic
thank you!
Added subscriber: @digital0785
Added subscriber: @EAW
18,800 objects is hardly simplified.
Also your daily build is 3 weeks old.
However, I can confirm that I am able to reproduce with
59b16e28d9
The 3 lights that should be occluded from view are visible once the volumetric view distance is set to 220' or further.
Here is the file with only the necessary objects.
Graphics card: GeForce GTX 470/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35
I tested with today's 2.81 it was still broken, I already had the thread created and file uploaded but didn't hit submit.
My apologies on the large file i left the arena in there and such as i mostly deal with larger areas and didn't know if that would cause issues and i did see it in other areas when moving around just that was the easiest one to find.
Also you guys are awesome with the speedy feedback :) is the area lights generating from a point something or just a current short coming off Eevee?
Added subscriber: @kosblend
Increasing the
Samples
in theVolumetrics
panel seems to solve the problem, so I don't think this is a bug.flare3.blend
still same bug present 2 years later, samples are at 256 and cannot go higher yet you can still see it through the object.. have tested on 2.93, 3, and 3 with ssgi build. all have the issue present and it's not just if the light is inside the object I've had it happen in other projects not setup like this I just deleted the light as I was in the middle of a time crunch
apparently the response I had previously typed wasn't posted. But it seems like a bug as I wouldn't imagine thats its intended display when it was working properly in 2.8
