Blender Running extremely slow on Intel IRIS and Windows #71287
36 Participants
Reference: blender/blender#71287
Microsoft Surface Laptop 3 13.5"
Graphics card: Intel(R) Iris(R) Plus Graphics Intel 4.5.0 - Build 25.20.100.7101
CPU: Intel Core i7 1065G7
RAM: 16GB LPDDR4X @3733 mhz
Drivers are up to date, this is a fresh windows install without other programs apart from Chrome, Autohotkey, Slack and Whatsapp, which all have been turned off.
Broken: version: 2.82 (sub 1), branch: master, commit date: 2019-11-01 22:10, hash:
e83a23acb2
Every other version of 2.8 I tried is also not working.
Worked: 2.79
Blender runs extremely slow, the viewport is laggy and has hang spikes every few frames, resizing the window is slow and every action takes half a second. I could only find references to this behavior happening on Macs (the behavior is similar to https://developer.blender.org/T56996). I'm pretty sure that this is tied to my hardware as I've tried the same build on another similarly powered device and didn't get the behavior there. I'm suspecting the Iris graphics, as that is a similarity with some of the macs that reportedly had this problem.
The Problem gets a little less worse when going into render view once, it stays that way when moving back, though still not usable. I'm not sure how to enable the --debug-gpu thing so I haven't tried that, the Debug Menu (23 if that's correct) shows this, but opening it doesn't have any noticeable effect:
I'm pretty sure this is not reproducible without the same hardware, As this happens directly on opening a fresh download of blender, no changes to anything with the default scene.
Video of the Problem:
Blender 2019-11-02 12-07-26.mp4
Added subscriber: @Ordenritterlein
#73112 was marked as duplicate of this issue
I'm not sure how to get this seen, but this makes 2.8 literally unusable and it is definitely a problem with Blender and the hardware, not my specific pc setup, since it appears on a clean windows install. I presume the problem is with all 10th gen intel chips. and a few older ones. (specifically the Iris graphics line) .
Added subscriber: @BrendTheCow
I can confirm this issue on my Surface Pro 7 (also 10th Gen Intel with Iris Plus). I've tried both updating the graphics drivers to latest (had to force, as they weren't authorized for this device yet), and testing on every Blender version from 2.80 to 2.82. It makes the software completely unusable.
It should be mentioned that this problem persists across both Eevee and Cycles viewport renderers, regardless of whether or not Cycles is set to CPU or GPU. I installed Maya 2019.2 to see if it also had issues with the 3D viewport stutter (which would indicate inherent driver issues instead of Blender issues), but Maya renders 3D objects in the viewport without any stutter.
Added subscriber: @rboxman
Yes, lack of hardware will make this difficult to address. In the meantime please try the following:
blender_debug_gpu_glitchworkaround.cmd
file (just double-click it) that should be right next to your blender.exe. When finished, drag and drop the 2 log files here (the location of the files will be opened in Explorer for you when closing blender)This isn't a support system but reporting back after doing those 2 items will help the devs investigate eventually.
Hi Roger,
Thanks for the help! To answer your questions:
Can confirm. I'm running 26.20.100.7372 currently, and previously ran 26.20.100.7xx1 (earlier version, but can't remember specific build number) - same issue on both.
Done and done: blender_system_info.txt blender_debug_output.txt
While this isn't a support system, I do hope the devs take a look at this soon. Fingers crossed!
One more thing for completeness. It looks like you're using 2.80. Can you try 2.81 (or 2.82) available for download here (just unzip locally and run): https://builder.blender.org/download/
Same procedure. Try with and without the debug script and upload logs if necessary.
Hey Roger,
Thanks for taking the time, it's getting really frustrating having to use 2.79 again^^
Latest Blender 2.82, latest intel driver (26.20.100.7372)
The issues appear to have not changed in any way.
Added subscriber: @brianf
I'm encountering the same issue on a Surface Pro 7 with Iris Plus G7 graphics as well. Digging around I see https://developer.blender.org/T70922 which looks to be the same issue. I have the latest master branch 2.82 built locally with debug symbols and Intel driver 26.20.100.7372.
Added subscriber: @Viiince
I have an identical issue on the Dell XPS 13 7390 2 in 1 (Intel i7-1065G7 with Intel IRIS)
Graphics drivers: 25.20.100.7102
Hey Vincent, can you upload the logs as well? I haven't been able to see a similarity between them and logs from a working machine, but the more info we get the better.
I took some performance traces and saw that most of the render time was being spent in workbench_solid_draw_background, 60% of a 1 second sample, on the 10th gen Iris Plus graphics.
While on Intel HD 630 graphics, workbench_solid_draw_background was only taking up 10% of the 1 second sample.
Added subscriber: @VincentMaurer
Hey Christoph,
Here are the logs you requested
Added subscriber: @katmanthree
Hi Christoph,
I've attached my logs as well, for a Dell Inspirion 3000 series laptop with an Intel i5-1035G4 running Intel's graphics driver version 26.20.100.7463. Might make sense to merge this with https:*developer.blender.org/T70922 and https:*developer.blender.org/T71555 as it seems this issue applies for all Iris Plus Graphics cards.blender_system_info.txt
Added subscriber: @c19130064
2.81 and 2.82 both share the same issus. I have to use 2.79 for now. Please give some advice?
Added subscriber: @patrickmros
Added subscriber: @JosefNobach
I have the same issue with my Surface Pro 7 i7. I have an entire thread here about this issue.
BLender artist Laggy viewport
Blender Running extremely slow on Surface Laptop 3to Blender Running extremely slow on Intel IRIS and WindowsAdded subscriber: @mano-wii
Since many are reporting the same issue, I set the report as a high priority, but we still need a developer who can reproduce the problem :\
Added subscriber: @michealparks
Added subscriber: @Teralink
I have the same issue with my Surface Pro 7 with Intel i7-1065G7 CPU, 16 GB Ram, Windows 10 and Intel Iris Plus Graphics.
Added subscriber: @pancake-manicure
Added subscriber: @floetenmaul
Added subscriber: @b.c.m.janssen
I'm having the same issue on my Surface Pro 7 i5-1035G4 as well.
Added subscriber: @kettunenf.lassi
Added subscriber: @gryphus
The issue still exists in Blender 2.83 alpha.
Added subscriber: @Jeroen-Bakker
Looking at the video it seems like a GPU/Driver issue. As cycles viewport is reacting more smoother than the workbench I can imagine that the driver is having trouble loading/unloading data.
Can someone do the same test, but with the debug value set to 22. (f3 -> Debug menu -> 22 -> ok) and record it with via an external source (mobile phone) So we can compare in which area the GPU does not excel.
As the architecture is new, and we don't have that architecture it is hard for us to fix the issue. I would expect that the driver isn't optimized for our load, but we might need to help out the driver a bit. I will set the issue to known issue for now until a gpu dev has their hands on a similar device.
Added subscriber: @FionNoir
Hi @Jeroen-Bakker,
When you say the same test do you mean perform the same actions as in the video attached to the opening post of this thread?
same pc, 2.83 alpha, Date 2020-01-10 17:32, hash
01d9a2f71b
I've done the test with the debug menu before, as some people with the problem on mac suggested it goes away when you enable it, but I only attached a static image before.
order of operations: Load, set debug to 22, duplicate, set to rendered in eevee (which improves viewport performance slightly for camera turning and such, but not for moving objects), switch to cycles.
as you can se the difference is hugely noticeable, even through the crap smartphone recording. I hope that helps. Blender Recording.mp4
Added subscriber: @aguy73
I just wanted to add that my new Surface Laptop 3 "15 intel with a 1065g7 based cpu doesn't work correctly with any 2.8x. I have tried 2.81a, and dev 2.82 and 2.83. I'm getting the similar problem of low viewport framerate, making Blender essentially unusable.
Added subscriber: @blu3bird
Added subscriber: @KlausJJ
Same issue on Lenovo Yoga C940.
system-info.txt
Added subscriber: @Philongo
Hello, I just wanted to say that I have been using Blender 2.8A with my surface pro 7, i7 model for the past week with no issues with the exception of the first 6 to 10 minutes which happen to be laggy but once it clears I have no issue what so ever with it. I agree there is a problem but I'm glad I can use it with my surface.
I can not confirm this on a Surface Laptop 3 with similar i7 CPU (1065G7). Even after half an hour it is still laggy. Have you changed any settings?
So I did not change any of my setting, but I did do some testing to see what would what be the quickest way I could get my laggy/choppy performance to act normal and I found out that if I open: File/New/Sculpting and start doodling my performance will fix itself within 2 to 3 mins but if I start with the normal general modelling my computer with take between 10 -20 mins to fix itself and If I just open blender in a let the computer sit idle with the application open it does nothing, I thought maybe the files took longer to load and thats the reason why it took so long to fix itself but that's clearly not the issues. If I could provide anything please let me know.
I can confirm, at least from my side that viewport performance kind of returns to normal after noodling around a few minutes in sculpt mode (as described, new File -> sculpting).
the change happened rather abruptly after randomly applying strokes. Menus still operate laggy though, adding a separate material for example still hangs for seconds at a time.
I have not tested if much, if it's specific to a view (pane, windows subdivision, never knew what those were called) for example.
Added subscriber: @Stavv
Also confirming. Smooth as butter (including menus) after messing around in sculpt mode for a few minutes.
Blender Version: 2.83 (sub 4)
Specs:
XPS 13 7390 2-in-1
Windows 10, 10.0.18362 Build 18362
Intel(R) Core(TM) i7-1065G7
32 GB RAM
Intel Graphics driver version 26.20.100.7463
Haven't tested with production Blender 2.82 but it seems like the lag got worse in 2.82 compared to 2.81.
Added subscriber: @hamC
Also confirming. Sculpt mode fixes the viewport somehow after a couple of minutes. But its' not a solution.
Specs: Surface Laptop 3 with i7-1065G7
Can Confirm on a Surface Pro 7 - i7 model. The sculpt mode trick kind of works but going back to the normal object view brings the lag back, making it unusable. Gotta use 2.79 for now which luckily works perfectly :(
Added subscriber: @gokarter64
also can confirm with a surface pro 7 i7, it handles blender 2.79 perfectly however 2.8 is still not running properly the sculpt mode trick works but if i sit idle for too long it will slow right back down. actions are still delayed regardless of what i do
Added subscriber: @ahmess
can confirm poor performance on my i5 surface pro 7. i've tried using version 2.8, 2.82, and 2.83 alpha but none shows any significant performance difference. sculpt mode doesn't seem to help at all in my case.
specs:
Surface Pro 7 - i5-1035G4
8GB RAM
Intel Graphics Driver version 26.20.100.7641
Added subscriber: @teejay5
Confirming poor performance on Surface Laptop 3 i7 16gb and Surface Pro 7 i7 16gb. Changing the render mode to Cycles, then turn viewport shading to "Rendered" makes it smoother, but switching to any other viewport shading mode brings the issue back.
Added subscriber: @SpencerTerry
Has there been an update in the development of this issue recently? Using brand new Surface Pro 7 i7 and experiencing the exact same issues.
@SpencerTerry We did some indept performance checks and the viewport isn't lacking it is the rendering of the properties panel. We send this issue to Intel to come with direction.
By default the object panel is open. And gets updated when moving the active object in the 3d viewport. The 3d viewport is fast. The bottleneck is in the property panel and font drawing. This part of blender uses a wrapper to convert legacy OpenGL calls to core profile calls. It seems that the Intel driver is not performing well when creating many of these calls. You can test that yourself when you switch to the render tab in the property panel. This makes the UI more interactive.
If we want migrate the legacy OpenGL calls to core profile calls I would estimation 3 months full time work for a single developer (1 year lead time). Which might be redone when moving to vulkan. The most cost effective and quickest solution is that Intel would solve this issue in their driver. They are aware of this request and we are waiting for their response.
Added subscriber: @ghostmafaldo
Apparently the problem is in turbo boost of the intel microprocessor, this controls the speed of the microprocessor, I understand that when the tablet is connected to the outlet, the microprocessor works at full power, otherwise it works at half speed .
This option also detects when a program requires more computing power and activates turbo mode.
Is that confirmed? The problem is the same for me when the device (Surface Laptop 3) is plugged in, but Turbo Boost issues would maybe explain why the viewport performs better when it's in Cycles render mode, right? Or is there another explanation?
I highly doubt it has to do with the turbo clock. If that were the case we would see a difference in performance between battery and plugged in. It acts the same way regardless. I really think its an issue with the newest version of open gl for windows when running on 10th gen intel devices.
By the way i installed ubuntu in dual boot on my surface pro 7 i7 this week and blender 2.8 runs perfectly smooth on linux.
@gokarter64
I just got the Surface 7 as well, would you be able to give me some tips on how you installed Ubuntu on your laptop? Thanks.
Here is a link to the project. You can use any linux version i personally just have experience with ubuntu https://github.com/linux-surface/linux-surface/wiki/Installation-and-Setup/_history
@gokarter64
Thank you!
Added subscriber: @baswein
I haven't tried it but does this fix the issue?
https://developer.blender.org/D7357
Temporary Solution:
On Blender Artists it was discovered that an experimental April 10th build of 2.83a had resolved most of the issue. I haven't played around with it too much but its pretty smooth from the get-go. The most recent builds bring the issue back, but that was because someone reported crashing and they're still working out the kinks. Full release is scheduled for May 20th, I believe, but this is a great sign that things will be fine for Iris Plus users.
Ive attached the April 10th build below for those who are needing 2.8x asap--but it is experimental!
blender-2.83-a8d139ca2002-windows64.zip
Added subscriber: @Doomer1122
Blender 2.90 Alpha has come out. I love to do work on my Surface Pro 7 as its very light weight, the surface pen, resolution, etc. Its a wonderful portable workstation for me. While its not the most powerful unit, it does exactly what I need from it. That being said, I created an account here (Been shadowing this post) to report that 2.90 Alpha has come out and upon first launch of it, the stuttering and performance issue is nearly gone immediately. There is a noticeable FPS drop in the view port than what I am use to from my main PC, and from the work around listed above (Sculpting in 2.83a), however menus work flawlessly. The FPS drop is the only performance issue left that I can feel. Hopefully, depending on the person, the performance may not be bad. For me, I do not mind it. Hopefully this will improve over time. Gives me high hopes.
Added subscriber: @brecht
The main fix for this is in both 2.83 and 2.90.
I'm closing this as a duplicate of #70922 (Intel IRS / Ice lake GPU slow viewport performance) which is still open to improve performance further, since that's where most of the information is.
Added subscriber: @welcometohe1l
Hello everyone! I ran into the problem of a slow interface and I FIX IT.
My characteristics:
Two graphics cards are installed in the laptop: NVIDIA Geforce 1050 and Intel HD Graphics 630. It turned out that the video card from Intel is not detected in the system. After turning it off in the device manager, the blender began to work quickly. However, after rebooting the blender, it again worked slowly. For it to work well, you had to enable and disable the video card from Intel. Later, I decided to update the drivers for the Intel graphics card from the official website and it began to display correctly in the system. The blender began to work quickly without complaints.
