Animating hide_viewport propertie deselect objects #71335
7 Participants
Reference: blender/blender#71335
Operating system: Linux-4.15.0-20-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 418.87.01
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-11-03 03:57, hash:
8ab6ef30ab
When animating the "hide_viewport" propertie of an object it deselect it, this was not the case in 2.79.
Not only the selection is lost but this make the user unable to use filters "Selected only" in combination with "Display hidden" like you could do in 2.79
{F7930271, size=full}
Animate the hide_viewport visibility of an object, in graph editor toggle on Selected only and Display hidden. Select the object and then scrub in/out the animated hide range, object gets deselected.
Example blend : animated_display_on_cube.blend
Someone also mentionned it in blender stack exchange with gifs to compare 2.79 and 2.8+ behavior : https://blender.stackexchange.com/questions/147876/hiding-object-in-2-80-via-animated-disable-in-viewport-loses-selection
Thank you !
Added subscriber: @Pullup
#94757 was marked as duplicate of this issue
#85150 was marked as duplicate of this issue
Added subscribers: @dfelinto, @lichtwerk
Afaict, blender always made hidden objects unselected [animating viewport visibility was an exception there, so to say]
So in a way, 2.8 is more consistent here, and I assume this is all by design [@dfelinto: correct me if I am wrong.]
Will have to close this, as I dont see a bug here.
(there might be usecases where this is inconvenient, for more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug)
Ok, thank you for your quick answer. I guessed this was maybe by design but was not sure...
If it is though, I consider this a regression since this exception allowed to keep selections and, more importantly, retime animation of visibility without showing every object in dopesheet (life-saver in dense scenes).
Is there a workaround to move visibility keyframes without them disappearing (by losing selection) ?
Added subscriber: @EAW
You can click off the check box labeled "Does F-Curve contribute to result."
Added subscriber: @chakravarthy
Sorry to add an entry here although this thread says closed (I'm new to this, but I had to share on this this topic)
Please consider this as use-case. Consider 3d motiongraphics, where you need to key the visibility of objects often. for the time being we cannot have the visibility animation show up in viewport without losing our selections. It is very important to be able to play/scrub the animation as we refine the timing of keyframes. Below is the situation shown as an image. For now the workaround I am having is to keyframe the scaling to zero if I want objects hidden. Something tells me this is not the right way.
Please don't hesitate to point out, if I am missing something.
Added subscribers: @comvico, @mano-wii
Given the repercussion of this issue with even a post on the rightclickselect about it (https://blender.community/c/rightclickselect/Zgfbbc/),
I think it is worth setting this as at least a "
".Changed status from 'Archived' to: 'Confirmed'
Added subscriber: @dr.sybren
This is indeed not a bug, but a design choice that was made for Blender 2.80. It's certainly annoying for certain workflows. The idea behind the change was as a solution to a very annoying other problem, where artists lost a lot of work because they unknowingly performed operations on invisible objects. By the time they made them visible, it was too late because their changes had already been saved so many times, the incremental backups didn't help either. AFAIK this decision was made by prioritising the loss of work over other work becoming more cumbersome.
Added subscriber: @phoenixart
