Frequently missing settings
Open, Needs Information from UserPublic
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
Frequently occurring issue, where when exporting the FBX, there are all settings missing on any surface of the interface, unable to define any settings.
Just comes and goes, without logic.
Win 10 x64
Nvidia GTX 1060 6GB
v2.80
I just figured out workaround.
I was in UV Editing workspace, while exporting. (object mode). It didnt show the settings for export to FBX.
While I went to Layout workspace, it magically appeared when I went to export the FBX.
So there is in fact a bug.
Philipp Oeser (lichtwerk) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Tue, Nov 5, 11:18 AM
Not sure I understand correctly...
Are you saying you are missing the export entries from this menu?
Do you happen to have Filter Addons enabled in the UV Editing workspace by any chance?
(if this is the case, then yes, the Import-Export Addons are missing -- which should not be the case -- this is a known issue being worked on atm though and would be a duplicate of T58842: Add-ons Import/Export entries disapear when enabling Filter Addons option)
Or can you actually call the FBX export and these settings are missing?
In my case it is the last picture. Sorry for not being clear enough before. I will provide photos from UVediting workspace -- Export -- FBX and then another photos going from Layout workspace -- Export -- FBX.
Between the photos, all I did was click from one workspace to another:
You appear to be using an older version of Blender, we've recently done a big redesign of the file browser UI, and changed a couple of things regarding these settings. You could try if it works in the latest builds, https://builder.blender.org/download/.
