MeasureIt radius does not take global scale factor into account #71375
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#71375
Operating system: Linux - Fedora 30
Graphics card: GeForce RTX 2070
Broken: 2.80
(example: 2.79b release)
The MeasureIt addon is reporting radius as though the distance between verts is at default scale, not scale set in global Unit Scale.
Pick 3 verts in correct order
Click "Arc" button in MeasureIt panel
Observe results of radius value
MeasureIt.blend
Added subscriber: @Psyonic
Added subscriber: @EitanSomething
Is this still an issue with 2.83?
Yes, but slightly different issue.
This image is the original .blend I uploaded with no modifications taken in 2.8.3
This image is starting from scratch in 2.83, changing the scene units to mm, scale to 0.001
It's a bit hard to see because of the colours, but, the radius shows 20.00m. 20.00 is correct, but it should be displaying mm.
