Grease Pencil Sculpt mode - clone brush and select
Open, Confirmed, LowPublic
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.15
Broken: version: 2.82 (sub 1), branch: master, commit date: 2019-10-27 17:59, hash: rBdd904f67614b
The clone brush requires you to copy a brush before you can use it. In Blender 2.80 you have a select menu in all submodes. In Blender 2.82 you miss the select menu without masking submode.
Now for the bug: without masking you can call the select tools by hotkey, but you can't use it. And this means that the clone tool requires to be in a selection mask mode so that you can select, copy and clone the brush.
Open Blender, create a grease pencil object. Switch to Sculpt mode. Activate the Clone brush. Press C to select what you want to clone. You can't.
Philipp Oeser (lichtwerk) lowered the priority of this task from Needs Triage by Developer to Confirmed, Low.Nov 8 2019, 12:54 PM
This was added in rB85f90ed6fd88.
I see this is now more in line with mesh vertex/weightpaint.
In regards to the bug (being able to call the select tool by hotkey) -- I think we should also be in line with mesh vertex/weightpaint (where calling the select tool by hotkey is prohibited).
(Probably happens in poll function?)
