Error message pops up when I use the "draw line" tool in the 2D animator
Closed, InvalidPublic
I use a surface pro 6, 8 gb of ram
Operating system: windows 10
Graphics card: Intel UHD
2.81
Broken: Draw line tool does not work, error message comes up
An error claiming wait I assume to be an error in the code comes up when I try to use the "draw line" tool, I assume this to be an error becuae part of the pop-up claims " file '<string>', line 1, in <module>
AtrributeError: 'SpaceVeiw3D' object has no attribute 'context'.
there is other code but that just seems like gibberish tool
I opened up blender then I went right on the 2D animation, I then used the line tool, then the error message popped up
Jacob (GetWaffled) created this task.
I am not sure if I did anything wrong but...
Jacob (GetWaffled) removed Jacob (GetWaffled) as the assignee of this task.Nov 8 2019, 12:29 AM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Nov 8 2019, 1:24 PM
I cannot reproduce this with either the latest stable or current development versions of Blender:
Please try the latest daily build: https://builder.blender.org/download/
Please also try with File → Defaults → Load Factory Settings to see if you still can reproduce this issue.
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Unknown Status.Nov 22 2019, 11:02 AM
