animation of the material
Closed, InvalidPublic
Operating system: Windows
Graphics card: GeForce GTX 1060 6GB
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
2.79 (sub 0), branch: master, commit date: 2018-03-22 14:10
Created an animation of the material. But the frame itself is not updated until I select the parameter.
Play the animation.
You cannot use a shader socket (output of the Mix Shader Node) as input of a value socket.
Use something else instead (replacing with MixRGB is fine...)
Dont see a bug here, closing...
Roman (Xsana) removed Philipp Oeser (lichtwerk) as the assignee of this task.Sat, Nov 9, 9:40 AM
Many thanks
