Align to Transform Orientation precision issue #71438
Reference: blender/blender#71438
Broken: 2.8x
Align to Transform Orientation introduces a small error in orientation.
In my case, the new orientation of the cube, while close to (0, 0, 0), is actually (0.000001, -0.000002, 0). This, in turn, results in accumulation of small "errors" in coordinates when translating the object along its axes. Running the operator a second time seems to make the orientation (0, 0, 0) though.
Added subscriber: @Stan_Pancakes
Added subscriber: @zazizizou
This inaccuracy is expected, see https://devtalk.blender.org/t/inaccuracy-of-values-in-transform/2655/4
No. That thread talks about inaccuracies that accumulate while editing. These are indeed to be expected. Aligning to orientation is not a temporal operation. It should, if at all possible, match the object's orientation with the desired one, otherwise it's at best a "Try to align". Right now it's just calculated with floats, which contributes to the discrepancy listed in the task description.
If I move the cube around and do slightly different rotations then I get different values than the ones you wrote above. We are talking about the 7th digit in -0.000002, which is around the limit of floating point arithmetics. Note that these are indeed incorrect values but the behavior is expected in the sense that Blender cannot have any higher precision than that because it uses floats to represent real numbers.
Whether we should round such numbers for display is a different issue I think.
What are you talking about? Final orientation is already known and is represented to the precision available. Aligning an object should match that orientation to the same precision, not approximate it. It's not about rounding of final result, at all.
Added subscriber: @Lambdadelta
Interestingly, that
bpy.ops.transform.transform()
operator has "Accurate" parameter (use_accurate), that is set by default to False.But toggling in on have no effect on align precision. Does anyone know why it there?
While in this special case, the exact target orientation is known, the code that computes this has to deal with more complex situations. E.g. when the object is parented to some other rotated object. Then when aligning it to world coordinates is more difficult than just copying the values over.
Blender could have a special case for the case you describe, but I think it is fine if it does not have it. Therefore, do not consider this to be a bug. It is working as expected with an error smaller than the machine precision.
"Special" case would be the parented one. Trivial case should be indistinguishable from copy-pasting the orientation.
