Macro operators [e.g. Loop cut and slide]: "adjust last operation" fails completely [when called from the menu -- F9 is fine] #71470
Reference: blender/blender#71470
Broken: 2.8x
Worked: 2.79b
This might fall into the same boat as anything related to #45964, although it does seem to be "new" in 2.8x.
After performing a loop cut and slide operator, you can adjust the properties in the operator panel (albeit with caveats from #45964). However, if you instead open the Adjust Last Operation panel, it will list a different operator name (Loop Cut, not Loop Cut and Slide), and while you can change properties there, those changes have no effect, even though they are reflected by the operator panel.
This didn't use to happen in 2.79b, though IIUC the "Adjust..." panel is different in 2.8x from the "Redo Last" of the 2.7x era.
Demo video
Added subscriber: @Stan_Pancakes
#73293 was marked as duplicate of this issue
Added subscriber: @lichtwerk
Seems to work fine when done via the F9 shortcut, can confirm though this seems to fail if called via the menu... checking...
Loop cut and slide: adjust last operation fails completelyto Loop cut and slide: adjust last operation fails completely [when called from the menu -- F9 is fine]Same is true for all macro operators, e.g.
MESH_OT_offset_edge_loops_slide
also fails.Loop cut and slide: adjust last operation fails completely [when called from the menu -- F9 is fine]to Macro operators [e.g. Loop cut and slide]: "adjust last operation" fails completely [when called from the menu -- F9 is fine]
