Adjust last operation: can't reset properties to default value
Open, Confirmed, MediumPublic
Broken: 2.8x
In the Adjust Last Operation panel, the context menu for any property has the Reset to Default Value options disabled, although they are enabled in the operator panel.
  1. Load the default scene
  2. Enter edit mode on the cube
  3. Bevel an edge
  4. Expand the operator panel in the bottom left
  5. Right click any property, note that Reset to Default Value option is enabled and works
  6. Go Edit -> Adjust Last Operation
  7. Right click the same property in that panel, note that Reset to Default Value option is disabled
Philipp Oeser (lichtwerk) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.Nov 11 2019, 12:52 PM
Can confirm this one also.
Note T71470 is very related [even though in this case -- opposed to T71470 -- it doesnt work well when called via F9 either...]
