Anomaly when displaying RGB data in the image editor #71482
Reference: blender/blender#71482
Graphics card: GeForce GTX 760/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.12
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash:
f6cb5f5449
I point out an anomaly "(most likely) that I noticed during the compositing phase. When I display RGB (and not RGBA) data in the image editor (or in the backdrop) I get an incorrect result where the alpha is gray Here is an example.
I have set a resolution of 1024x1024 at 100% in the properties.
I created an "Image" node in the compositor and generated a UV grid with a 1024X1024 resolution without alpha channel to have any image (RGB).
I created a matte, using "Box Mask" to get any alpha.
I connected the "Box Mask" node output to a Blur and softened the mask slightly.
I created a "Set Alpha" node and connected the UV grid of the Image node to the RGB and the Blur output to the Alpha.
When I visualized both in the image editor and in the background the result of the "set alpha" I obtained the UV grid of the shaded by the alpha, so far But when I changed from "Color and Alpha" to "Color" from the Display I got an "anomalous" image: the Uv grid with the (white) edges of the matte above.
I get the same result also using Separate RGB + Combine RGB, connecting the UV grid in RGB and the blurred Matte in A when I display the RGB in the image editor.
bug_alpha.blend
Added subscriber: @RobertoAngelino
Added subscriber: @Jeroen-Bakker
Added subscriber: @lichtwerk
Isnt this because
Use Alpha
is checked on theViewer
/Composite
nodes?(Colors are treated as alpha premultiplied then). Need to check again how this is supposed to be looking...
Of course, if I turn off the alpha in the viewer it "seems" to work but at this point if I want to see "only" the alpha channel I can't. In theory, if I want to see only RGB using a node that does not "multiply" as Set Alpha or SeparateRGB + Combine RGB I would expect to see the "RGB" (and not "RGBA") data intact without the influence of the alpha ( alpha which seems to be added more than multiplied). The alpha channel, however, should be kept waiting for a node like "Convert Alpha" which multiplies by RGB.
Then I don't know if it's normal for behavior ... but if it is I don't understand the sense ...
I think the current behavior is more correct in the current design. Changing it to work as you describe probably requires some deeper thinking about the implications this has for color management in the compositor (which I'm not really able to do so far). In any case, this is out of the scope for a bug report. So I'll close this as invalid because this white border is kind of expected.
