Calling bpy.ops.object.select_all from driver throws Runtime error
Open, Needs Triage by DeveloperPublic
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon HD - FirePro D500 OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.11.20
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-11-14 09:40, hash: rBc25a910e4ec0
Calling bpy.ops.object.select_all(action='DESELECT') from driver throws:
BPyOpsSubModOp._view_layer_update(context)
File "/Applications/Blender 2.81.app/Contents/Resources/2.81/scripts/modules/bpy/ops.py", line 159, in _view_layer_update
  view_layer.update()
RuntimeError: Error: Dependency graph update requested during evaluation
This is independent of the value of action. Not sure if this is bug or a change of design, but it used to work on 2.79{F8077517}
2.80 will get in an infinite loop, 2.81 throws an error.
From Workspace "Scripting" Run script driver_functions.py to register driver
Switch to Workspace Animation
A driver function "invert" is installed in the Scene object for the Alpha property with input from "prop"
With the driver selected, execute Update Dependencies
Console will show error listed above.
Related Objects
