Texture disappearance Export bug
Needs Developer to Reproduce, NormalPublic
Operating system:Windows7 Home Premium 64bit
Graphics card:NVIDIA Quadro K600
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen) 2.81
After upgrading from version 2.80 to 2.81, there was a problem that part of the texture of the model disappeared when opening the file.
There was also a bug that the add-on was checked but could not be converted to FBX format.
Occurs after updating to 2.81.
Stephen Swaney (stiv) lowered the priority of this task from 90 to 30.Nov 24 2019, 12:10 PM
Please include a description of the problem and how to reproduce it.
Stephen Swaney (stiv) renamed this task from テクスチャ消滅と出力不具合 to No Title.Nov 24 2019, 12:11 PM
石川 知実 (Clive) renamed this task from No Title to Texture disappearance Export bug.Nov 24 2019, 12:46 PM
石川 知実 (Clive) updated the task description. (Show Details)
Please attach the corresponding .blend file then and try to explain what exactly you mean by
  • part of the texture of the model disappeared when opening the file (screenshot might help here)
  • the add-on was checked but could not be converted to FBX format
Philipp Oeser (lichtwerk) raised the priority of this task from 30 to 90.Dec 17 2019, 12:48 PM
Jacques Lucke (JacquesLucke) changed the task status from Needs Triage to Needs Information from User.Jan 8 2020, 12:58 PM
Please describe what we are supposed to do with that file to see the issue. We have to be able to reproduce it, to fix it.
It looks like you did not pack the texture into the .blend file.
Opening data in Blender 2.81 results in a broken screen like the above image
Richard Antalik (ISS) changed the task status from Needs Information from User to Needs Developer to Reproduce.Jan 16 2020, 12:12 PM
