Select expand/contract from face mode to edge mode doesnt flush to faces if there are zero edges selected after contraction #71879
Reference: blender/blender#71879
Broken: 2.79b, 2.80, 2.81, 2.82 (
ba1e9ae473
)Short description of error
With certain selections, switching from face to edge mode with the Expand option deselects edges, but leaves faces selected.
Faces will remain selected, but all edges around them will be deselected.
Added subscriber: @Stan_Pancakes
Added subscriber: @AnthonyEdlin
Can at least confirm behavior as described. In addition what seems to trigger it is when you ctl click from faces to edges and it would leave no edges selected, it then leaves the faces selected in edge mode. If you then ctl click back to faces they will still be selected. In contrast, if even 1 edge is selected when you first ctl click to edge mode then the faces are unselected and when you ctl click back to face mode only the faces connected to the selected edge are selected.
Linux-5.3.0-20-generic-x86_64-with-Ubuntu-18.04-bionic 64 Bits
GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.26
Blender version: 2.81 (sub 16), branch: master, commit date: 2019-11-20 14:27, hash:
26bd5ebd42
That last part is normal operation: "Expanding" from a single edge is supposed to select the faces connected to it. But I'm not sure what you mean by "if even 1 edge is selected when you first ctrl click to edge mode"?
Yes the last part is normal operation. The part that is wrong is that if you go from faces to edges and in the process no edges are selected (because you don't have any adjacent faces selected) then the faces remain selected even in edge mode. The faces should be unselected in this case but they are not. If you then ctl click expand back to face mode you would think that no faces would be selected because no edges were selected in edge mode, but now the faces that were selected at the start are still selected.
I notice that EDBM_selectmode_convert function is what does the expansion/contraction. All mode switches that go down from higher to lower use BM_mesh_deselect_flush except for the one that goes from faces to edges. I made a patch that just adds BM_mesh_deselect_flush to that code path also, seems to work for me. #71879.diff
Added subscriber: @lichtwerk
@AnthonyEdlin: guess that would work.
This only happens when there are zero selected edges left after contraction.
Usually this already gets flushed in
EDBM_selectmode_set
(which happens a bit afterEDBM_selectmode_convert
inEDBM_selectmode_toggle_multi
)But there, flushing only takes place if there are non-zero edges selected.
Maybe we should even do it there like so [havent tested thourougly though...]?
P1169: T71879_snippet
Select Expand from face mode to edge mode may produce invalid selectionto Select expand/contract from face mode to edge mode doesnt flush to faces if there are zero edges selected after contractionAdded subscriber: @ideasman42
CC @ideasman42
@lichtwerk Yes I only added it there because the other spots inside EDBM_selectmode_convert that do a contraction use it. Such as Face->Vert and Edge->Vert. It could work in either place, but I think that either way they should be consistent. So maybe remove other flushes in EDBM_selectmode_convert. I am no bmesh expert though.
Looks like this has just been fixed, see
b0b6fb8a93
(same solution @AnthonyEdlin suggested)
