Saving the same project generates different blend files
Closed, InvalidPublic
Operating system: Ubuntu 18.04
Graphics card: Radeon r9 Fury X
Broken: Release 2.81
Worked: looks like affecting all versions
It seems that with blender I can't reproduce the same project file even if there is no changes in the project. Probably it's related to the date is saved into the file or some additional time-related information, but probably it's not the correct behavior - for example it's quite hard to check that the project have no modifications since the previous save.
Hopefully we could have an additional checkbox that will cut all the time-related information from the blend file during the save process? That will really help with automation and reproducible project files.
  1. Open blender with default startup file
  2. File -> Save as copy to test1.blend
  3. File -> Save as copy to test2.blend
  4. md5sum test1.blend test2.blend
  5. Checksum will show that 2 files are different
Bastien Montagne (mont29) changed the task status from Unknown Status to Invalid.Nov 27 2019, 11:41 AM
This is totally expected, there would be meta-data changes, and we basically dump current memory in .blend file at writing, so you will *never* get the same checksum with two different saves.
