Undo unavailable for Remove Vertex Group in edit mode #71980
9 Participants
Reference: blender/blender#71980
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.01
Broken: version: 2.82 (sub 1), branch: master, commit date: 2019-11-27 03:54, hash:
4fd99c9495
Bug description
After remove a vertex group from a mesh while in edit mode, the undo operator still works, but undo buffer does not seem to contain the remove vertex group operation, so using undo undoes whatever was done before the removal of vertex group. On entering object mode, using undo will undo the vertex group removal operation before any mesh editing, leading to confusing out-of-order undo operations
Repro steps:
Create new mesh
Create vertex group
Switch to edit mode
Move a vertex to make an obvious visible change
Remove vertex group
Move another vertex visibly
Switch to object mode
Use 'undo' operator multiple times
'undo' operator will undo vertex transforms, and appear to do nothing when it reaches the point in the undo buffer where it ought to undo 'remove vertex group'
Use 'undo' operator
Removed vertex group is back, and edit mode is active
I won't lay out all of the variations, but for more complicated failure modes with weirder out-of-order undo operations, try:
move vertex, remove group, move other vertex, switch to object mode, use undo function
create two vertex groups before entering edit mode, move vertex, delete first vertex group, move another vertex, delete second vertex group, move a third vertex. Enter object mode and use 'undo' operator
system-info.txt
Added subscriber: @AdrianPreston
#96192 was marked as duplicate of this issue
#92026 was marked as duplicate of this issue
#78022 was marked as duplicate of this issue
Added subscriber: @Stan_Pancakes
Brace for incoming "this is a limitation of current undo system". Which exists for eons now :(
It wasn't present in 2.7x, if that helps. Has the undo system been redone?
It was present. You can't undo removal of vertex group in edit mode. In 2.7x and in 2.6x.
Well I'll be damned. I just checked, and I could have sworn it worked, but you are right. Well, still... I guess it is for devs to decide if it is a bug or not, but it certainly isn't as the user would expect.
Unfortunately, that is probably a known limitation indeed..
Added subscribers: @michaeleconomy, @mano-wii
Added subscriber: @ckohl_art
Added subscribers: @borschberry, @PratikPB2123
Added subscriber: @Ethan-Hall
Blender currently prevents users from removing material slots while in edit mode. Can we similarly limit the ability to remove vertex weights and other attributes to protect users from out of order undo side effects until the undo system is reworked?
Added subscriber: @Emwardicus
Added subscriber: @DaveyJolms
