GPencil: deleting interpolated frames causes crash #72020
Reference: blender/blender#72020
Graphics card: AMD Radeon HD 5700 Series ATI Technologies Inc. 4.5.13417 Core Profile Context 15.301.1901.0
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-11-20 14:27, hash:
26bd5ebd42
I've tested 2.8 and 2.82 alpha, both crash as well
Deleting one of a few specific grease pencil frames created by "Interpolate Sequence" reliably crashes Blender. Deleting a shape in the frame also produces the same result.
I've had this happen once or twice before, but I never paid it much mind since it seemed random. Here's a file where it happens rather predictably, however.
20191128_gp_headturn.blend
Added subscriber: @Nelfie
Added subscriber: @antoniov
I have deleted all frames from 30 to 40 and my system doesn't crash.
Do you have any log of the crash?
The kind of log produced by the following instructions?
When run normally, the console produces this error on crash:
If I run
blender.exe --debug
the console gives these errors instead...... for the most part, but a crash has also occured, giving the
ACCESS_VIOLATION
error above.One information I forgot in my initial post: I'm using a portable version of Blender, maybe that has something to do with it.
Added subscriber: @lichtwerk
@lichtwerk Can you reproduce it?
Grease Pencil: deleting interpolated frames causes crashto GPencil: deleting interpolated frames causes crashYes, can reproduce. What I did:
X
>Delete Keyframes
X
>Delete Keyframes
X
>Delete Keyframes
Doesnt seem to crash in the same places, a bit weird, maybe we should check with ASAN as well?
It is totaly reliable crash, had a couple of sessions [some of which survived without crash], but here are the backtraces of two sessions where it crashed:
@Nelfie Did you noticed if this is only for interpolated frames? never had the same issue with hand draw frames?
@lichtwerk I have seen there is a problem whith weight free memory...if you look at the console, you will see a "Couldn't unmap memory". I guess there must be an issue when interpolate frames and the weights are not created as expected (almost sure, the weights arry is not initializated propertly).
I can't tell for sure. I use interpolation a lot - and they're the frames I delete most often, in large groups, since they need to be re-done whenever I modify a key.
I'll keep track of it if the same bug occurs again and let you know. (As long as it's relevant to fixing the problem, of course)
@lichtwerk I have submitted
1321be0af9
and I think this was the reason of the error. Could you recompile and try again?Really, the problem was not in the frame delete process, but in how the interpolated sequence frames were created. The problem was when the number of points of the destination stroke were less than original stroke and the weights array had to be resized. By a mistake, it was resizing the original stroke instead of the new interpolated stroke, and this corrupted the pointers... and after that corruption, anything can fail.
@Nelfie Can you reproduce the bug with the last buildbot? You must check with anew file...the old file already damaged can fail.
I'll try as soon as possible.
I assume I should reproduce the specific situation you described in the previous comment, yes? Also, is a single file enough, or should I make multiple in case the bug is random?
@Nelfie Yes, just create a new file and try to reproduced the steps to create the bug. I hope the fix avoids the error you had in your file.
So, I tried to reproduce the bug in 2.81 first, to make sure I was going through the right steps - but I haven't managed to make the bug happen again. Here's what I did:
It doesn't cause a crash, so unless it's random, I'm missing something. Any ideas?
Try painting weights in the strokes before interpolate, but if my fix worked all must go fine.
Ah, yes, that was it, thank you! I had forgotten I had added vertex groups in the original file.
I tested the bug with a new file in 2.81, and the crash occurred as predicted. Using the same file in the latest 2.82 alpha (saved without interpolations), I went through the same steps, and no crash occurred. Same for the reverse (file made and tested in 2.82 alpha, then saved and tested in 2.81.)
So, problem fixed as far as I can tell. Good work!
Thanks @Nelfie for your testing. I'm going to close the report. If you have more problems, please, open a new report.
