length of the spline does not work after apllying hooks #72025
5 Participants
Reference: blender/blender#72025
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.30
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-11-20 14:27, hash:
26bd5ebd42
Let's create any of the splines in blender (nurbs, bezier) and then use know function: bpy.data.curves["NurbsCurve"].splines- [x].calc_length()
It's smoothly working. But after you apply hook modifier and move the empty somewhere, length does not change the value. Thant problem is crucial for custom squash with spline IK.
create spline >[edit mode] > select one of the vertices > ctrl+h > hook to new object > [object mode] > to Python console copy: bpy.data.curves["NurbsCurve"].splines- [x].calc_length() with correct name "NurbsCurve" or "BezierCurve" > a value > move the empty somewhere > again use console with same code > it gives same value even the legth was changed
Added subscriber: @MarcelLegindi
#81091 was marked as duplicate of this issue
Added subscriber: @mano-wii
As we can see in the code,
calc_length
is executed on thedata
of the object. That is, with no effect of any modifier.Different objects can have the same
data
, so there is no way for the code to know which modified object it should calculate the length of.Blender 2.8 has a bug with curve modifiers (#71055) changing all objects with the same
data
. But that will be fixed.Well, I don't understand, is it functional or not? When I use hook and move .. the calc_length does not work precise - so I do something wrong? If so, what exactly?
there is the proof - this is not working and its a bug. If I understand the usage.
To explain further...
We have: object, data and modifier.
Object = data + modifiers
The object is the Curve (NurbsCurve).
The data are the splines of the Curve (the data is confusingly also called NurbsCurve on this object, but the name can be changed in the properties).
The modifier is Hook.
calc_length
is a function of the data and not of the object.We can have more than one object with the same data:
ObjectA = data + modifiersA
ObjectB = data + modifiersB
Objects can have different lengths but the data remains the same.
I see, thank you. So is there any option how to measure the spline .. or some other method how to make custom squash besides ratio(spline_length/hooked_spline_length)*scaleY_of_the_bone ? ... you know if you have 15spine bones.. or 2 BBones and scale it properly by distance from the root?
I don't know off the top of my head (you may have to create a temporary mesh as a last resort).
Ok thank you very much ..But that's a pity. May I suggest to make it like new function somewhere in this forum? You know, control spline IK properly and fast is crucial for any cartoon character in rigging and trying to measure it by an array modificators is very slow for complex rigs.
Added subscriber: @Josephbburg
Is it possible to get an evaluated version of the curve data (not the mesh)?
Anyhow, about a year ago, I made a right-click-select proposal related to this problem. https://blender.community/c/rightclickselect/4ncbbc/ In the meantime, I've come up with a pretty good solution to the measurement problem for my addon, Chain Tools, which I'd be happy to share if you're interested.
When measuring a curve for a rig, especially for squash and stretch, it isn't necessary to get the actual measurements- you only really need to compare the base length to the posed length (for the y-axis scale). Then you can take the reciprocal of this measurement to set the scale for the x and z axes. I usually create a dummy spline IK that is set to space the bones out evenly. I make sure to apply the pose to edit mode a few times to prevent its length from changing when changing into pose mode. Then I can use the y-scale (local space) of any bone in the chain to measure the length of the curve - if the curve starts out at 5 units, and the bone's scale is 1.5, then I know the length of the curve is 5 * 1.5 = 7.5. This is usually good enough for whatever I want to do.
Thank you very much, Joseph. So if I understand right, you compare true (start) length of the spline (without modifiers) with IK-spline chain length with scaleY turn on, by basic bone length * its scale after stretching.
I asked in blender.stackexchange if somebody wants more solutions: https://blender.stackexchange.com/questions/159714/custom-squash-and-stretch-without-spline-length-ratio/159719?noredirect=1#comment270625_159719
Added subscribers: @elie, @lichtwerk
